tjayz wrote: ↑Tue Oct 24, 2023 11:06 pm
To be clear, the two yield the exact same quality rpu no scene detect advantage or anything else?
original scene cuts in CM is better but the difference is not big.
Is there a guide buried in this thread somewhere that covers this?
if you use the dovi_scripts, it's not too complicated.
automated: workflow 8-6-2
manual (with staxrip or in cli x265.exe):
1. workflow 7-1 in manual mode.
2. edit the avs script: remove the text overlay and uncomment convertbits(10)
3. convert the rpu to p8.
4. encode the avs file just like any HDR video file(with the rpu or inject it after the encode).
I might order this and give it a test and return if it sucks as described, as it seems strange they boast passthrough yet you are getting lpcm which has no atmos.... If passthrough did work and one gains cmv 4.0 , and if can somehow tweak those stutters this is a very appealing device.
not worth it.
Not true TV-LED and no 24fps support. DV MKV works great but most of my TS/M2TS give me a green or black screen. The Shield also stopped working with DV TS.
The ATV is the best solution for DV MKV rip IMO... Plus the TS/M2TS rip works (cant be FF/RW or resumed though)
And when Infuse will (I hope) add cmv4.0 support, it will be even better.
I can't help but think those stutters are related to onboard wifi issues, maybe using AC or even N signal would be more stable than AX.
its not a wifi issue. I tried the AC ethernet adaptor and it keeps buffering with the high bitrate test file.
