Is there a guide buried in this thread somewhere that covers this?yes but it requires re-encoding.
To be clear, the two yield the exact same quality rpu no scene detect advantage or anything else?latest Resolve and CM use the same 2023 new algo
I might order this and give it a test and return if it sucks as described, as it seems strange they boast passthrough yet you are getting lpcm which has no atmos.... If passthrough did work and one gains cmv 4.0 , and if can somehow tweak those stutters this is a very appealing device. I can't help but think those stutters are related to onboard wifi issues, maybe using AC or even N signal would be more stable than AX.Same issues and same stuttering with high bitrate video. I also could not get DTSHD nor TrueHD passthrough to work, all I got is LPCM like the old firetv.
