Rush - Moving Pictures
durian
#1 Post by durian » Wed May 11, 2011 4:16 pm
Makemkv fails with the Rush - Moving Pictures blu ray disc. After it scans the m2ts tracks, but before it gives you a list of titles, it crashes with an internal error.
mike
crowfax
Re: Rush - Moving Pictures
#2 Post by crowfax » Wed May 11, 2011 5:16 pm
Turn on debugging and post the log please.
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
durian
#3 Post by durian » Thu May 12, 2011 5:25 pm
Here is the debug log.
durian
#4 Post by durian » Thu Jun 30, 2011 6:27 pm
1.6.11 does not fix this problem. MakeMKV still crashes after reading the tracks.
cbxbiker61
#5 Post by cbxbiker61 » Thu Sep 08, 2011 12:39 am
I just tried with 1.6.14. It still crashes. Probably because it's an audio disc, with no video. So I mounted the disc. Here's a directory listing in case that helps.
./AACS
./AACS/Content000.cer
./AACS/ContentHash000.tbl
./AACS/ContentRevocation.lst
./AACS/CPSUnit00001.cci
./AACS/DUPLICATE
./AACS/DUPLICATE/Content000.cer
./AACS/DUPLICATE/ContentHash000.tbl
./AACS/DUPLICATE/ContentRevocation.lst
./AACS/DUPLICATE/CPSUnit00001.cci
./AACS/DUPLICATE/mcmf.xml
./AACS/DUPLICATE/MKB_RO.inf
./AACS/DUPLICATE/MKB_RW.inf
./AACS/DUPLICATE/Unit_Key_RO.inf
./AACS/mcmf.xml
./AACS/MKB_RO.inf
./AACS/MKB_RW.inf
./AACS/Unit_Key_RO.inf
./BDMV
./BDMV/index.bdmv
./BDMV/MovieObject.bdmv
./BDMV/PLAYLIST
./BDMV/PLAYLIST/00000.mpls
./BDMV/PLAYLIST/00001.mpls
./BDMV/PLAYLIST/00002.mpls
./BDMV/PLAYLIST/00003.mpls
./BDMV/PLAYLIST/00004.mpls
./BDMV/PLAYLIST/00005.mpls
./BDMV/PLAYLIST/00006.mpls
./BDMV/PLAYLIST/00007.mpls
./BDMV/PLAYLIST/00008.mpls
./BDMV/PLAYLIST/01000.mpls
./BDMV/PLAYLIST/01001.mpls
./BDMV/PLAYLIST/01002.mpls
./BDMV/PLAYLIST/01003.mpls
./BDMV/PLAYLIST/01004.mpls
./BDMV/PLAYLIST/01005.mpls
./BDMV/PLAYLIST/01006.mpls
./BDMV/PLAYLIST/01007.mpls
./BDMV/PLAYLIST/01008.mpls
./BDMV/CLIPINF
./BDMV/CLIPINF/00000.clpi
./BDMV/CLIPINF/00001.clpi
./BDMV/CLIPINF/00002.clpi
./BDMV/CLIPINF/00003.clpi
./BDMV/CLIPINF/00004.clpi
./BDMV/CLIPINF/00005.clpi
./BDMV/CLIPINF/00006.clpi
./BDMV/CLIPINF/00007.clpi
./BDMV/CLIPINF/00008.clpi
./BDMV/STREAM
./BDMV/STREAM/00000.m2ts
./BDMV/STREAM/00001.m2ts
./BDMV/STREAM/00002.m2ts
./BDMV/STREAM/00003.m2ts
./BDMV/STREAM/00004.m2ts
./BDMV/STREAM/00005.m2ts
./BDMV/STREAM/00006.m2ts
./BDMV/STREAM/00007.m2ts
./BDMV/STREAM/00008.m2ts
./BDMV/AUXDATA
./BDMV/AUXDATA/sound.bdmv
./BDMV/META
./BDMV/META/DL
./BDMV/META/DL/bdmt_eng.xml
./BDMV/META/DL/Rush_thumbnail_416.jpg
./BDMV/META/DL/Rush_thumbnail_640.jpg
./BDMV/BDJO
./BDMV/BDJO/00000.bdjo
./BDMV/JAR
./BDMV/JAR/00000
./BDMV/JAR/00000/firstplay.nbi
./BDMV/JAR/00000/firstplay.png
./BDMV/JAR/00000/main.0.aca
./BDMV/JAR/00000/main.1.aca
./BDMV/JAR/00000/main.2.aca
./BDMV/JAR/00000/main.3.aca
./BDMV/JAR/00000.jar
./BDMV/BACKUP
./BDMV/BACKUP/BDJO
./BDMV/BACKUP/BDJO/00000.bdjo
./BDMV/BACKUP/CLIPINF
./BDMV/BACKUP/CLIPINF/00000.clpi
./BDMV/BACKUP/CLIPINF/00001.clpi
./BDMV/BACKUP/CLIPINF/00002.clpi
./BDMV/BACKUP/CLIPINF/00003.clpi
./BDMV/BACKUP/CLIPINF/00004.clpi
./BDMV/BACKUP/CLIPINF/00005.clpi
./BDMV/BACKUP/CLIPINF/00006.clpi
./BDMV/BACKUP/CLIPINF/00007.clpi
./BDMV/BACKUP/CLIPINF/00008.clpi
./BDMV/BACKUP/index.bdmv
./BDMV/BACKUP/JAR
./BDMV/BACKUP/JAR/00000
./BDMV/BACKUP/JAR/00000/firstplay.nbi
./BDMV/BACKUP/JAR/00000/firstplay.png
./BDMV/BACKUP/JAR/00000/main.0.aca
./BDMV/BACKUP/JAR/00000/main.1.aca
./BDMV/BACKUP/JAR/00000/main.2.aca
./BDMV/BACKUP/JAR/00000/main.3.aca
./BDMV/BACKUP/JAR/00000.jar
./BDMV/BACKUP/MovieObject.bdmv
./BDMV/BACKUP/PLAYLIST
./BDMV/BACKUP/PLAYLIST/00000.mpls
./BDMV/BACKUP/PLAYLIST/00001.mpls
./BDMV/BACKUP/PLAYLIST/00002.mpls
./BDMV/BACKUP/PLAYLIST/00003.mpls
./BDMV/BACKUP/PLAYLIST/00004.mpls
./BDMV/BACKUP/PLAYLIST/00005.mpls
./BDMV/BACKUP/PLAYLIST/00006.mpls
./BDMV/BACKUP/PLAYLIST/00007.mpls
./BDMV/BACKUP/PLAYLIST/00008.mpls
./BDMV/BACKUP/PLAYLIST/01000.mpls
./BDMV/BACKUP/PLAYLIST/01001.mpls
./BDMV/BACKUP/PLAYLIST/01002.mpls
./BDMV/BACKUP/PLAYLIST/01003.mpls
./BDMV/BACKUP/PLAYLIST/01004.mpls
./BDMV/BACKUP/PLAYLIST/01005.mpls
./BDMV/BACKUP/PLAYLIST/01006.mpls
./BDMV/BACKUP/PLAYLIST/01007.mpls
./BDMV/BACKUP/PLAYLIST/01008.mpls
./CERTIFICATE
./CERTIFICATE/app.discroot.crt
./CERTIFICATE/BACKUP
./CERTIFICATE/BACKUP/app.discroot.crt
./CERTIFICATE/BACKUP/bu.discroot.crt
./CERTIFICATE/BACKUP/id.bdmv
./CERTIFICATE/bu.discroot.crt
./CERTIFICATE/id.bdmv
linux-man
#6 Post by linux-man » Thu Sep 08, 2011 2:14 am
Dude,that's a bummer!!! I love Rush!!!!
crowfax
#7 Post by crowfax » Thu Sep 08, 2011 3:16 am
Have you done this: http://www.makemkv.com/faq/item/8 ?
durian
#8 Post by durian » Thu Sep 08, 2011 3:35 am
I did. I forwarded log files and a core dump.
setarip_old
#9 Post by setarip_old » Thu Sep 08, 2011 11:15 pm
@durian
Hi!
Try the following:
1) Make an ENCRYPTED FULL DISC copy
2) Make an .MKV from the FULL DISC copy
durian
#10 Post by durian » Thu Sep 08, 2011 11:39 pm
@setarip_old
I'll give this a try tomorrow. Did you get access to the core file too? Was there something in there to indicate parsing a copy would succeed?
durian
#11 Post by durian » Fri Sep 09, 2011 8:12 pm
I don't think this is unexpected, but running MakeMKV on an encrypted copy of the disc crashes too.
bartman
#12 Post by bartman » Thu Nov 10, 2011 9:15 pm
Having the same issue here. AnyDVD can rip the disc without error, but then when trying to read the decrypted disk iso with MakeMKV I get:
unfrostedpoptart
#13 Post by unfrostedpoptart » Thu Jul 25, 2013 6:41 pm
Hi all.
I've just been getting into BD-Audio with a Samsung USB Bluray drive attached to my Mac Mini. However, I just got the Moving Pictures disk and am hitting the error that it failed creating the output file. It works for the first title, which is just a short animation, and the 3rd title, which has a couple of videos. However, the main, 2nd title fails.
Is this the same error you were seeing almost 2 years ago? Was there never a fix or response from the makemkv developers for this after such a long time?
Help!?!?!
David
Here's a screen capture:
#14 Post by mike admin » Mon Jul 29, 2013 8:09 am
unfrostedpoptart wrote:Is this the same error you were seeing almost 2 years ago? Was there never a fix or response from the makemkv developers for this after such a long time?
p!?!?!
Yes, because there was no follow up. Please, please,please - do submit a test dump for the title that fails per instructions at /onlinehelp/testdump.html
unfrostedpoptart
#15 Post by unfrostedpoptart » Mon Jul 29, 2013 5:32 pm
p!?!?!
Actually, I found a better way for audio-only files. I used makemkv to make an unencrypted backup of the disk. Then I used DVD Audio Extractor to pull out the audio. Works great.
David
