Logitec LBD-PWA6U3L (HL-DT-ST_BD-RE_BP71N_1.03_212202181625_SIK02M5EI0200) needs BU40N Firmware
Vamp898
#1 Post by Vamp898 » Tue Oct 24, 2023 6:00 am
Hi there,
just wanted to inform you that the above mentioned drive can not be used with 4K BluRays. So if anyone wants to buy that (because its relatively cheap), don't
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Re: Logitec LBD-PWA6U3L Not working for 4K (HL-DT-ST_BD-RE_BP71N_1.03_212202181625_SIK02M5EI0200)
#2 Post by MartyMcNuts » Tue Oct 24, 2023 7:47 am
Vamp898 wrote: Tue Oct 24, 2023 6:00 am Hi there,
Can you show us the drive info from MakeMKV?
Vamp898
#3 Post by Vamp898 » Tue Oct 24, 2023 10:08 am
Do you mean this?
Debug log started at Tue Oct 24 05:58:10 2023 , written by MakeMKV v1.17.5 win(x64-release)
001005:0000 MakeMKV v1.17.5 win(x64-release) started
No  SDF v098: HL-DT-ST_BD-RE_BP71N_1.03_212202181625_SIK02M5EI0200
DEBUG: Code 0 at oKy{<P[rsI9$ xH93:29396253
DEBUG: Code 0 at 6XX(~WMlif ;_K(I:213136746
DEBUG: Code 3 at p#THBi/ll*BA2gQ6"dN^+C5W:29395310
SDF id v098: HL-DT-ST_BD-RE_BP71N_1.03_212202181625_SIK02M5EI0200
DEBUG: Code 2147483648 at ]K}<{g 5\^[xCzt/:121265499
DAFD=PAAAADAAAAEABDQgEHwECAQ==
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Or an screenshot from the interface?
#4 Post by Billycar11 » Tue Oct 24, 2023 10:15 am
Vamp898 wrote: Tue Oct 24, 2023 10:08 am Do you mean this?
no he means the dive info side bar before you open the disc
#6 Post by Billycar11 » Tue Oct 24, 2023 11:01 am
Vamp898 wrote: Tue Oct 24, 2023 10:51 am Ah, got it. This here, right? https://photos.app.goo.gl/sLjYmRBJT2BDjhYL6
yeah its probably some bp60/BU40n derivative but not sure, mike would know best if we should just cross flash this or it should get its own dedicated mk fw
or you could risk it and flash it
your be best to reach out to him just be patient and willing to give him remote access to your drive and know your way around the cmd a bit as thats required for his drive remote access tool
Vamp898
#7 Post by Vamp898 » Tue Oct 24, 2023 11:10 am
If cross-flashing would brick it, would it still be possible to continue or is it gone then?
I tried to read the firmware with sdftool but it does nothing, the target folder stays emtpy (so i assume its not able to read it)
#8 Post by Billycar11 » Tue Oct 24, 2023 11:13 am
Vamp898 wrote: Tue Oct 24, 2023 11:10 am If cross-flashing would brick it, would it still be possible to continue or is it gone then?
it may be imposable to fix if it has no sata interface or your pc does not have ide mode
Vamp898
#9 Post by Vamp898 » Tue Oct 24, 2023 11:24 am
It looks like an BU40N that was put into an plastic case. If i open it, the internals are identical, they even use the same korean cables and also the buttons and so on are at the same place.
And the plastic case it resids in is, no question, an OEM case. I am 99% sure this is an BU40N. Its from an Japanese Maker by the way.
Does that mean the chances are high it will work? Or is this unrelated?
Vamp898
#10 Post by Vamp898 » Tue Oct 24, 2023 11:34 am
I just pulled the trigger and cross-flashed the 1.03MK from the BU40N, works perfectly, rip is in process without any issues whatsoever.
Thank you so much for pointing this out, saved me money (because this drive is significantly cheaper than the buffalo) and i can finally watch my 4K BluRay in all its glory =)
