BDR-XD06JUHD UHD Ripper GOD
Fanboy85
#1 Post by Fanboy85 » Sun Oct 22, 2023 10:01 am
hey guys, i bought this little guy on ebay few years ago to play my 4K original movies but the problem is that my new laptop and my new pc desktop has a intel 13th gen Raptor Lake and is not compatible anymore with 4K playback discs, i have read here that this drive is compatible to flash? or it works directly?, im very newbie about all this, can you show me the path to the Dark side?
EDIT:it just works with make MKV guys, i just can't play the m2ts files that it dumps, dont know what im doing bad :? :? :?
DONE GUYS!!!!!! MY DRIVE IS WORKING NOW!!!!
i want to thank very much to
for the help!
Re: BDR-XD06JUHD UHD Ripper GOD
#2 Post by Billycar11 » Sun Oct 22, 2023 1:01 pm
Fanboy85 wrote: Sun Oct 22, 2023 10:01 am hey guys, i bought this little guy on ebay few years ago to play my 4K original movies but the problem is that my new laptop and my new pc desktop has a intel 13th gen Raptor Lake and is not compatible anymore with 4K playback discs, i have read here that this drive is compatible to flash? or it works directly?, im very newbie about all this, can you show me the path to the Dark side?
Its an older drive so it should just work if it has older fw so don't update it.
Fanboy85
#3 Post by Fanboy85 » Sun Oct 22, 2023 4:38 pm
Billycar11 wrote: Sun Oct 22, 2023 1:01 pm
THX dude, u're right, it just works with makeMKV, o have made already 3 backups of my original discs but the problem now is that i can't play the files well using powerdvd, VLC or dvdfab player, when i try to play m2ts file of the movie powerdvd says that is not compatible format
#4 Post by dcoke22 » Mon Oct 23, 2023 5:51 am
VLC should play .m2ts files. I've never used powerdvd or dvdfab so I don't know how they work.
Fanboy85
#5 Post by Fanboy85 » Mon Oct 23, 2023 10:52 am
dcoke22 wrote: Mon Oct 23, 2023 5:51 am VLC should play .m2ts files. I've never used powerdvd or dvdfab so I don't know how they work.
i can.t play the video files i have dumped, i have made the dum without the option "decrypt video files"
i think this is the reason why i can't play the files i dump, the dumps are 100% of its original size but then i can't play it without that option activated and if i activate the function then i can't dump de disc, i got errors
can someone help me with me?
#6 Post by dcoke22 » Mon Oct 23, 2023 5:49 pm
As I understand it, you'll need to have the decrypt option turned on when you make a backup for VLC to be able to play the resulting .m2ts files.
What are the errors from trying to make a decrypted backup?
Often the errors indicate that the optical drive was unable to correctly read the optical disc. The standard advice is to gently clean the disc and try again.
Fanboy85
#7 Post by Fanboy85 » Tue Oct 24, 2023 10:43 am
dcoke22 wrote: Mon Oct 23, 2023 5:49 pm As I understand it, you'll need to have the decrypt option turned on when you make a backup for VLC to be able to play the resulting .m2ts files.
Backing up disc into folder "C:/Video/backup/KING_KONG_UHD"
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Saved AACS dump file as C:\Users\toyo3/.MakeMKV/MKB20_v61_KING_KONG_UHD_6C6F.tgz
Backup failed
#8 Post by dcoke22 » Tue Oct 24, 2023 2:49 pm
Fanboy85 wrote: Tue Oct 24, 2023 10:43 am Backing up disc into folder "C:/Video/backup/KING_KONG_UHD"
Backup failed
"CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT" is one I haven't seen before. :D
It does make me wonder if LibreDrive is properly enabled for your drive. Post the contents of the Info box (right side of the window) on the first screen in MakeMKV, just after you start the program but before doing any operations.
Fanboy85
#9 Post by Fanboy85 » Tue Oct 24, 2023 5:35 pm
dcoke22 wrote: Tue Oct 24, 2023 2:49 pm
Backup failed
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-XD06U
Revision: 1.00
Serial number: QFDL001332JP
Firmware date: 2017-02-24
Highest AACS version: 61
Drive platform: Pioneer RS8B30
Firmware version: ID69
#10 Post by Coopervid » Tue Oct 24, 2023 8:45 pm
You need to contact Mike to support your firmware or send a PM to me.
Fanboy85
#11 Post by Fanboy85 » Wed Oct 25, 2023 11:23 am
Coopervid wrote: Tue Oct 24, 2023 8:45 pm You need to contact Mike to support your firmware or send a PM to me.
i have contact you on PM
#12 Post by Coopervid » Wed Oct 25, 2023 11:51 am
Fanboy85 wrote: Wed Oct 25, 2023 11:23 am
Check your PM
Fanboy85
#13 Post by Fanboy85 » Wed Oct 25, 2023 12:30 pm
for the help!
