Do you know which version of firmware for Pioneer X13U-S is the last libre one? I am not sure whether for this particular drive it is 1.01 or 1.02?
Thank you in advance
Re: Pioneer firmware update February 2023
1.02phidix wrote: Sat Oct 14, 2023 1:10 am Hello,
phidix
Thank youMartyMcNuts wrote: Sat Oct 14, 2023 4:25 am1.02phidix wrote: Sat Oct 14, 2023 1:10 am Hello,
Mattl0
What is the best drive working with libre available to buy ?
Any Pioneer drive available from a seller on here in your area.
Mattl0
Thanks! I just wonder why there is such a big difference between the higher priced Pioneer models and the lower Pioneer ones?
The more expensive models usually have slightly better quality (or additional) components. Pioneer, in general are still better build quality overall though.Mattl0 wrote: Wed Oct 18, 2023 10:12 pm Thanks! I just wonder why there is such a big difference between the higher priced Pioneer models and the lower Pioneer ones?
diabloxp
Do you know whether there is any information regarding progress / ETA for making it possible to use Pioneer recorder BDR-X13E-S (and many other Pioneer devices with recently updated firmwares) with firmware 1.03 (not libredrive for now) with MakeMKV for UHDs?
I'm aware many people are waiting for that and my question is whether there is even a chance for that or rather not?
Mike the developer is looking at the new firmware there is no news other then that thoughdiabloxp wrote: Wed Oct 18, 2023 11:00 pm Do you know whether there is any information regarding progress / ETA for making it possible to use Pioneer recorder BDR-X13E-S (and many other Pioneer devices with recently updated firmwares) with firmware 1.03 (not libredrive for now) with MakeMKV for UHDs?
I'm aware many people are waiting for that and my question is whether there is even a chance for that or rather not?![]()
kululu
Hi all
I have changed new Pioneer X13S-J and firmware 1.03,and can’t use mkvmaker to rip 4K, Please for help! Thanks
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR -X13U
Revision: 1.03
Firmware date: 2022-12-12
Bus encryption flags: 18
Highest AACS version: 78
Status: Possible, not yet enabled Drive platform: Pioneer RS9401
Firmware version: ID43
OS device name: E:
Revision: 1.03
sadly the firmware is to new and cant be downgraded needs to be before 12/22kululu wrote: Sun Oct 22, 2023 9:32 am Hi all
OS device name: E:
Revision: 1.03
kululu
Billycar11 wrote: Sun Oct 22, 2023 10:35 amsadly the firmware is to new and cant be downgraded needs to be before 12/22kululu wrote: Sun Oct 22, 2023 9:32 am Hi all
OS device name: E:
Revision: 1.03
Oh…..so sad…Thanks for your reply
Krawk
I for one wish there was a time line. No doubt some of the deep groups out there have reverse engineered these drives, but it has not made it this way yet.diabloxp wrote: Wed Oct 18, 2023 11:00 pm Do you know whether there is any information regarding progress / ETA for making it possible to use Pioneer recorder BDR-X13E-S (and many other Pioneer devices with recently updated firmwares) with firmware 1.03 (not libredrive for now) with MakeMKV for UHDs?
I bought two S13U drives, one has the right firmware, one does not.
billbillw
Just making sure, a Pioneer BDR-212 built in 2019 with original 1.0 firmware should be a workable unit for UHD discs? Is there any advantage of upgrading it to one of the pre-12/2022 firmwares?
No major advantage long as it's a UHD model it should work and if it's not you can email me for a cross flash kit if it's before 12-22billbillw wrote: Mon Oct 30, 2023 5:09 pm Just making sure, a Pioneer BDR-212 built in 2019 with original 1.0 firmware should be a workable unit for UHD discs? Is there any advantage of upgrading it to one of the pre-12/2022 firmwares?
