Im Looking for a 12.7mm Internal drive
looking for a 12.7mm optical drive for my dell poweredge 530, all i can find is panasonic but unsure it they will work with libredrive
Re: Im Looking for a 12.7mm Internal drive
Panasonic will not do libredrive
I can't find it now but I think a long time ago I saw a spacer using a 9.5mm drive in a 12.7 slot.
If you can go for a pioneer they are way better
Nope. Get yourself a 12.7 to 9.5mm adapter and either a LG BU40N or a Pioneer BDR-UD04 (firmware dated before Dec 2022). Both drives can enable Libre drive and also allow you to rip UHD discs.
I have a BU40N on hand but i cannot find any kind of adapter
I have seen them before somewhere. Quite hard to find though... You might just be better of getting an external slim drive.
Some internet searching brought me back around to a thread I commented in here on this forum.
viewtopic.php?f=16&t=24910
A 9.5mm optical drive should line up and fit, electrically, in a 12.7mm bay. The screw holes might not line up. And the front plate on a 9.5mm optical drive is not going to cover the 12.7mm hole, but supposedly a 12.7mm front plate can be installed on the drive.
i got a Pioneer BDR-TD05, fits perfectly, but it has a odd firmware.
see: viewtopic.php?f=19&t=32332
That drive will never do UHD needs to be 8301 or higher.spl147 wrote: ↑Fri Nov 10, 2023 5:37 pmi got a Pioneer BDR-TD05, fits perfectly, but it has a odd firmware.
LibreDrive and reading UHD are not the same thing
That would of been nice to know! I thought libreDrives purpose was for UHD.Billycar11 wrote:That drive will never do UHD needs to be 8301 or higher.spl147 wrote: ↑Fri Nov 10, 2023 5:37 pmi got a Pioneer BDR-TD05, fits perfectly, but it has a odd firmware.
No it's to remove buss encryption and get around aacs revocationspl147 wrote: ↑Fri Nov 10, 2023 8:46 pmThat would of been nice to know! I thought libreDrives purpose was for UHD.Billycar11 wrote:That drive will never do UHD needs to be 8301 or higher.spl147 wrote: ↑Fri Nov 10, 2023 5:37 pmi got a Pioneer BDR-TD05, fits perfectly, but it has a odd firmware.
Do any up-front research?
Ultimate UHD Drives Flashing Guide Updated 2023 states:Drive Information
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-TD05
Revision: 2.00
Serial number:
Firmware date: 2012-08-10
Drive platform: Pioneer RS8211
Firmware version: ID72
1. Make sure your Drive was built after 2016 on label or late 2015...
What is LibreDrive?
That's not exactly true for pioneers the guide is LG focused pioneers can do UHD going back to 2013 bdr 208 and newer is kinda a good way to look at it but remember guys there is no public flasher for these you would have to spoof the pioneers flasher if you want to diyd00zah wrote: ↑Fri Nov 10, 2023 9:49 pmDo any up-front research?
Revision: 2.00
Serial number:
What is LibreDrive?
Ya live, ya learn.Billycar11 wrote: ↑Fri Nov 10, 2023 9:57 pm...
