LG BU60NB10 (Replacement Drive)
strubdog
#1 Post by strubdog » Fri Oct 20, 2023 11:19 pm
I just got a replacement drive back from LG. It's the LG BU60NB10 and is on firmware version 1.02, manufatured date of 0ctober 2022. Is it possible for me to flash it or this one of the new firmware's that make it hard to update the firmware? I currently can't use it with MakeMKV.
Re: LG BU60NB10 (Replacement Drive)
#2 Post by dcoke22 » Fri Oct 20, 2023 11:41 pm
strubdog wrote: Fri Oct 20, 2023 11:19 pm I just got a replacement drive back from LG. It's the LG BU60NB10 and is on firmware version 1.02, manufatured date of 0ctober 2022. Is it possible for me to flash it or this one of the new firmware's that make it hard to update the firmware? I currently can't use it with MakeMKV.
I don't know the specific answer to your question. However, the people on this forum who do know will likely want to see MakeMKV's info box about your drive (Both the Drive Information and the LibreDrive Information). Copy & paste that info here.
strubdog
#3 Post by strubdog » Fri Oct 20, 2023 11:46 pm
OS device name: I:
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIK08MABG1410
Firmware date: 2121-07-08 15:56
Highest AACS version: 78
Harware support: Yes
Firmware support: No
Firmware version: 1.02
#4 Post by Billycar11 » Sat Oct 21, 2023 12:54 am
strubdog wrote: Fri Oct 20, 2023 11:46 pm Drive Information
OS device name: I:
Revision: 1.02
see guide below
or email me to do it for you
Venoius
#5 Post by Venoius » Sat Oct 21, 2023 12:57 am
I have the same drive and firmware, so you aren't alone. Was working months prior, yet I believe a new blu ray helped "upgrade" the firmware. I also need a libredrive option.
