Currently when i attempt to use the software, it removes the activation key on start up, then restarts the application. I then attempt to enter in the beta key and restart the application and i fall into the same cycle. I am using the experimental 1.6.11
Logs:
Debug log started at Thu Jun 30 01:38:40 2011 , written by MakeMKV v1.6.11 win(x86-release)
001005:0000 MakeMKV v1.6.11 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Media/MakeMKV_log.txt
005073:0114 Your temporary key has expired and was removed. Please restart the application.
Application exited at Thu Jun 30 01:38:47 2011
Debug log started at Thu Jun 30 01:38:47 2011 , written by MakeMKV v1.6.11 win(x86-release)
001004:0000 Debug logging enabled, log will be saved as C:\Users\Media/MakeMKV_log_1.txt
Application exited at Thu Jun 30 01:40:11 2011
I get the same behavior on the 1.6.10 build.
Activation Key
Re: Activation Key
I have the same issue. It's not yet the end of the month and the current beta key is not working anymore. Intended behavior Mike?
BlackDragon24
Re: Activation Key
Key went dead for me too on 1.6.8. Was planning on trying 1.6.11 but need a new key to report back
- Contact:
Re: Activation Key
The key is updated.
