Thanks for the info but unfortunately, the FireTV device is probably the worst one for DV rip.
1- Overall a much darker image than all the other devices. Not a subtle difference, its very noticeable.
https://www.youtube.com/watch?v=1ZnPmBFuYtw
2- Stutter with high bitrate videos (I had to redo the firetv lldv capture about 3 times in that YouTube video)
5ghz wifi or USB to ethernet adaptor
3- Can't do true TV-LED meaning it's always the player that is processing the dynamic metadata.
4- Does some Dolby Vision IQ internally even if your TV is in cinema mode with DV IQ is set to off(greyed out)... This is related to L11 cmv4.0 which should only works when your TV is in Cinema Home mode with DV IQ on.
In this situation, is the preferred process to generate DV with CM_Analize/Resolve?RESET_9999 wrote: ↑Tue Oct 17, 2023 2:09 pm
Yeah, not surprised.
The HDR10 and P5 DV versions have different brightness and all those uploaders make P8 hybrid assuming its always the same.
https://slow.pics/c/doZxc4kj
More reasons to collect physical media. 2019 Shield TV Pro.
I guess...
I'm waiting on the bluray remux before making a final decision about this movie.
Not really worth it in my opinion, at this time, given UHD BD is 2 weeks away from retail and will have DoVi included.Gatorman wrote: ↑Wed Oct 18, 2023 3:04 pmIn this situation, is the preferred process to generate DV with CM_Analize/Resolve?RESET_9999 wrote: ↑Tue Oct 17, 2023 2:09 pm
Hey @RESET_9999
Thanks for answering my questions as I get a grip on this, I hope it hasn't been too annoying.
I made a copy of Scream 3 using 3-1 with a version of your program last week and it worked fine. However I wanted to remake it with the 1000 nit MDL as you advised, and now I'm getting errors.
https://imgur.com/a/L91XJky
Any thoughts?
Any thoughts?
forgot to test P7 input in 3-1. try next version or convert your input to P8.
No worries, I look forward to the next version.RESET_9999 wrote: ↑Thu Oct 19, 2023 12:15 pmforgot to test P7 input in 3-1. try next version or convert your input to P8.
@RESET_9999 Your FireTV is circular in the borders?RESET_9999 wrote: ↑Wed Oct 18, 2023 1:21 pmThanks for the info but unfortunately, the FireTV device is probably the worst one for DV rip.
Like in the picture.
https://www.amazon.com/dp/B0BP9SNVH9
nop but I'd be surprised if anything changed about DV.Hellboy. wrote: ↑Sat Oct 21, 2023 12:22 am@RESET_9999 Your FireTV is circular in the borders?
I might order one and return it just to find out .
Hi @RESET_9999 !
I tried 3-1 with profile 7 mkv input on your new version 1.9.7.
The process seems to run fine but at the end I'm left with a .mkv with only an audio track (no video). There's also a .bin file and a .hevc file which according to mediainfo has only hdr and no DV.
Muxing is disabled for P7 input until I have more time to work on that. The script should not have muxed anything though?dapope wrote: ↑Sat Oct 21, 2023 12:30 pmHi @RESET_9999 !
Just mux the HEVC file. FYI, an hevc or h265 file never has the DV flags, its normal.
No problem, I guess I can use TSMuxer to mux the the .hevc into a usable P8 file. I'm assuming I don't have to worry about the .bin file.RESET_9999 wrote: ↑Sat Oct 21, 2023 1:36 pmMuxing is disabled for P7 input until I have more time to work on that. The script should not have muxed anything though?dapope wrote: ↑Sat Oct 21, 2023 12:30 pmHi @RESET_9999 !
I tested some more and the .mkv with only an audio track is created if you say yes to the "convert audio to DDP" question.
5.1 DDP track is encoded straight to an MKV on purpose in order to preserve any delay if present.
dapope wrote: ↑Sat Oct 21, 2023 2:31 pmNo problem, I guess I can use TSMuxer to mux the the .hevc into a usable P8 file. I'm assuming I don't have to worry about the .bin file.
Hi @RESET_9999, could it be possible to make the tools path as a personal setting by moving them in the SETTINGS.bat file? I think it'd be useful for many people to void having multiple executables for the same tool spread out over the system.
yes sure, check out next version.
