phidix
Re: Pioneer firmware update February 2023
#106 Post by phidix » Sat Oct 14, 2023 1:10 am
Do you know which version of firmware for Pioneer X13U-S is the last libre one? I am not sure whether for this particular drive it is 1.01 or 1.02?
Thank you in advance
#107 Post by MartyMcNuts » Sat Oct 14, 2023 4:25 am
1.02
phidix
#108 Post by phidix » Sat Oct 14, 2023 4:11 pm
1.02
Thank you
Mattl0
#109 Post by Mattl0 » Wed Oct 18, 2023 9:17 pm
What is the best drive working with libre available to buy ?
#110 Post by MartyMcNuts » Wed Oct 18, 2023 9:23 pm
Any Pioneer drive available from a seller on here in your area.
Mattl0
#111 Post by Mattl0 » Wed Oct 18, 2023 10:12 pm
Thanks! I just wonder why there is such a big difference between the higher priced Pioneer models and the lower Pioneer ones?
#112 Post by MartyMcNuts » Wed Oct 18, 2023 10:48 pm
The more expensive models usually have slightly better quality (or additional) components. Pioneer, in general are still better build quality overall though.
diabloxp
#113 Post by diabloxp » Wed Oct 18, 2023 11:00 pm
Do you know whether there is any information regarding progress / ETA for making it possible to use Pioneer recorder BDR-X13E-S (and many other Pioneer devices with recently updated firmwares) with firmware 1.03 (not libredrive for now) with MakeMKV for UHDs?
I'm aware many people are waiting for that and my question is whether there is even a chance for that or rather not? :)
#114 Post by Billycar11 » Wed Oct 18, 2023 11:06 pm
Mike the developer is looking at the new firmware there is no news other then that though
kululu
#115 Post by kululu » Sun Oct 22, 2023 9:32 am
Hi all
I have changed new Pioneer X13S-J and firmware 1.03,and can’t use mkvmaker to rip 4K, Please for help! Thanks
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR -X13U
Revision: 1.03
Firmware date: 2022-12-12
Bus encryption flags: 18
Highest AACS version: 78
Status: Possible, not yet enabled Drive platform: Pioneer RS9401
Firmware version: ID43
#116 Post by Billycar11 » Sun Oct 22, 2023 10:35 am
Hi all
OS device name: E:
Revision: 1.03
sadly the firmware is to new and cant be downgraded needs to be before 12/22
kululu
#117 Post by kululu » Sun Oct 22, 2023 11:18 am
Hi all
OS device name: E:
Revision: 1.03
Oh…..so sad…Thanks for your reply
Krawk
#118 Post by Krawk » Sat Oct 28, 2023 10:35 pm
I for one wish there was a time line. No doubt some of the deep groups out there have reverse engineered these drives, but it has not made it this way yet.
I bought two S13U drives, one has the right firmware, one does not.
billbillw
#119 Post by billbillw » Mon Oct 30, 2023 5:09 pm
Just making sure, a Pioneer BDR-212 built in 2019 with original 1.0 firmware should be a workable unit for UHD discs? Is there any advantage of upgrading it to one of the pre-12/2022 firmwares?
#120 Post by Billycar11 » Mon Oct 30, 2023 6:34 pm
No major advantage long as it's a UHD model it should work and if it's not you can email me for a cross flash kit if it's before 12-22
