your display capabilities dont matter, you should use the correct MDL according to the content brightness.
dapope wrote:
Sun Oct 15, 2023 2:39 pm
If you have a display with a max brightness under 1000 nits, is there any point to using the 4000 nits option?
LV8HD wrote:
Sun Oct 15, 2023 3:01 pm
Hi guys, I'm working on the movie The Equalizer, and I want to inject Dolby Vision coming from the iTunes WEB-DL but I've noticed something I've never seen in a rpu:
I've never seen multiple values for L6 metadata, could anyone explain why?
yes it happens sometimes. I guess if you would play the movie in HDR10 on a device that can convert DV to HDR10, they would be used.
LV8HD
Post by LV8HD »
RESET_9999 wrote:
Sun Oct 15, 2023 3:04 pm
I see, thank you.
Draco1544
Post by Draco1544 »
With the RESET_9999 script, I can bake the EL and get the same bit rate (without compression) than the original movie ?
dapope
Post by dapope »
RESET_9999 wrote:
Sat Oct 14, 2023 1:35 pm
Trees wrote:
Sat Oct 14, 2023 8:41 am
Quick question; when generating CMv4.0 content (3-1), how does one determine what Mastering Display to use? I assuming higher isn't necessarily better?
2 options:
1- just use the static metadata from your source HDR10
2- check the brightness first with madvr. If 95% of the movie is under 1000nits, use 1000nits MDL else, 4000.
Option 2 is better because some movies have a static MDL of 4000nits but the actual brightness is under 1000nits.
A 4000nits RPU is a lot darker than a 1000nits one regardless of the content's actual brightness and in my opinion, 4000nits MDL + low nits content is wrong without L2 trim passes because if you look at the generated(or original) trims with a 4000nits analysis, they brighten/compensate a lot for the darkness a 4000 rpu brings.
https://slow.pics/c/uVX5iFOD
Is this an example of what you're talking about here? The MaxCLL basically doesn't go above 1000 nits, so I should choose 1000 nits for 3-1 despite the MDL being reported as 4000 nits?
https://imgur.com/a/VhPte1l
Also, how does expanded brightness via FEL factor into this? Scream 3 has FEL expanded brightness. Wouldn't the FEL brightness be taking it over 1000 nits?
dapope wrote:
Mon Oct 16, 2023 10:58 am
yes
FEL is the difference between the original master and the hdr10 encode. The difference can be anything they decide.
dapope
Post by dapope »
RESET_9999 wrote:
Mon Oct 16, 2023 2:09 pm
I'm sorry but I don't really understand how to act on this.
Say you have the following situation, as with Scream (your screenshots here: https://slow.pics/c/j9rBXDQU). The MDL is listed as 4000 nits.
The HDR plot goes barely over 1000 nits. Maybe, for the sake of argument, we could say that it doesn't really go over 1000 nits at all, like the plot I shared of Scream 3. But the DV plot goes much higher, almost to 4000 nits.
In this situation, using 3-1, should I choose the 1000 nits option or the 4000 nits option?
Thank you!
Tompi
Post by Tompi »
Mission Impossible - Dead Reckoning Part One in Dolby Vision Profile 8 is completely unwatchable on Philips TV.
Tried Apple TV 4K, Shield TV Pro but same picture. Plex and Vimu installed on the TV are the same.
If I buy the film from iTunes the picture is perfect and if I download the original Profile 5 version it is perfect.
What is causing the problem with Profile 8?
Profile 8:
https://freeimage.host/i/img20231014210744.JFn1NcJ
Profile 5/iTunes Movies
https://freeimage.host/i/img20231014215916.JFn1O8v
dapope wrote:
Tue Oct 17, 2023 2:18 am
Thank you!
As I said, you measure any video with madvr, if 95% is under 1000nits , you use 1000nits MDL in 3-1.
Fel dv plot has nothing to do with this.
Tompi wrote:
Tue Oct 17, 2023 9:38 am
Profile 8:
Yeah, not surprised.
The HDR10 and P5 DV versions have different brightness and all those uploaders make P8 hybrid assuming its always the same.
https://slow.pics/c/doZxc4kj
LV8HD
Post by LV8HD »
Hi guys, I've lately started generating hdr10+/dv for all my movies that don't have them. The first thing to do before generating comes to encoding an Apple ProRes version of the movie. For instance, one could set encoding to maximum quality and the resulting file will be huge, while I usually keep quality at 5 in which I found a good compromise between quality and space, so how much of importance does the ProRes quality have to do with the final result?
skull88
Post by skull88 »
LV8HD wrote:
Tue Oct 17, 2023 3:22 pm
I use -qscale:v 3 and RESET's script has -qscale:v 4, which I believe he found to be best overall compromise between speed/size and PQ/accuracy, if I'm not mistaken.
mtotheb
Post by mtotheb »
Apparently the new Fire TV Stick 4K Max (2Gen) 2023 16GB supports:
-Dolby TrueHD (Atmos) passthrough
-DTS passthrough
-DTS-HD passthrough (basic profile)
which is new.
Still no FEL / Profile 7 DoVi support per https://developer.amazon.com/docs/fire- ... ax_gen2_16 though.
„Dolby Vision support for Profile 4-MEL, 5, 8, 9 & 10. (Up to Level 9 for profiles 5, 8 and 10. Up to Level 5 for Profile 9)“
Shield TV 2017 -> LG DSN10YG Soundbar with SPK8 Rears -> LG B1 OLED
Thanks for the info but unfortunately, the FireTV device is probably the worst one for DV rip.
1- Overall a much darker image than all the other devices. Not a subtle difference, its very noticeable.
https://www.youtube.com/watch?v=1ZnPmBFuYtw
2- Stutter with high bitrate videos (I had to redo the firetv lldv capture about 3 times in that YouTube video)
5ghz wifi or USB to ethernet adaptor
3- Can't do true TV-LED meaning it's always the player that is processing the dynamic metadata.
4- Does some Dolby Vision IQ internally even if your TV is in cinema mode with DV IQ is set to off(greyed out)... This is related to L11 cmv4.0 which should only works when your TV is in Cinema Home mode with DV IQ on.
Gatorman
Post by Gatorman »
RESET_9999 wrote:
Tue Oct 17, 2023 2:09 pm
In this situation, is the preferred process to generate DV with CM_Analize/Resolve?
More reasons to collect physical media. Ugoos AM6B+.
