Submitted dump AACS dump file.
MKB20_v76_Willy_Wonka_and_the_Chocolate_Factory_36F7
Willy Wonka 4k volume key unknown
BrendanT123
Re: Willy Wonka 4k volume key unknown
Glad to see I'm not the only one! Also sent my dump file on Sunday. Checking back every day to see when it comes through.
As per the response the name of the dump I received was "MKB20_v76_Willy_Wonka_and_the_Chocolate_Factory_36F7"
Guys, when posting, please include the name of your dump file. This is so others can check these threads before they send in their dump as there's little point in emailing the same dump file again.
BrendanT123
Volume Key Unknown error "MKB20_v76_Willy_Wonka_and_the_Chocolate_Factory_36F7" has been fixed in latest HK download.
cadalyst97
Same issue
MakeMKV v1.17.5 win(x64-release) started
Using LibreDrive mode (v06.3 id=4083C4CCDB14)
Downloading latest HK to ...
Saved AACS dump file as .../MKB20_v76_Willy_Wonka_and_the_Chocolate_Factory_36F7.tgz
You need to find out what's blocking you from doing downloads. Probably your DNS. There are message topics about this.Automatic HK downloading is disabled or failed.
