BUG REPORT: "Revert" Reverts to the Wrong Order Weight
Radiocomms237
Post by Radiocomms237 »
The default value for the "Order weight" on all tracks is currently "90"
If you modify that value (to say "99"), but then change your mind and click the "Revert" button (to the right of the text field), it 'reverts' the value to "0", not back to "90" as it should.
Radiocomms237
Re: BUG REPORT: "Revert" Reverts to the Wrong Order Weight
Just downloaded and installed V1.17.6 and this bug wasn't fixed.
It still 'reverts' to zero.
best to try and tag mike then he might see it you can also try emailing him.
mike admin wrote:
