dump from BB steelbook submitted
MKB20_v77_Haunted_Mansion_2F88
						Haunted Mansion 4K
Re: Haunted Mansion 4K
Thanks for submitting it.  Mine will be here shortly.  Not that we're going to be able to get BB SB's much longer.
				polskasubie
yea i'm pretty gutted about Best Buy getting out of the game... rumor is the releases on Dec 5th might be it for steels... for all theirs faults, i almost always get their releases on the weekend or Mon... and Tue at the latest...
Amazon, Target, Walmart... almost always comes after release day
Yea it completely sucks.  I may look into ordering from other places that aren't quite as popular as Walmart.  Target seems to be following Best Buy as they offer less and less.  Best Buy hasn't put the Dial of Destiny preorder up yet, either.  The whole situation sucks.
Anyway, MKB20_v77_Haunted_Mansion_2F88.tgz has been submitted again just in case.
Any update on this? I am having the same problem
What kind of update are you looking for?  It's been supported for 2 months.  "I'm having the same problem" is not descriptive.
The same problem being that my copy wasn't loading a key. Surprisingly though it works now. Must have needed a restart after installing the latest version of MakeMKV
The keys should get downloaded automagically assuming the option is enabled in MakeMKV settings and nothing is blocking the connection to the update server.
