Willy Wonka 4k volume key unknown
nelskr4
Post by nelskr4 » Sun Oct 15, 2023 5:07 pm
Submitted dump AACS dump file.
MKB20_v76_Willy_Wonka_and_the_Chocolate_Factory_36F7
BrendanT123
Re: Willy Wonka 4k volume key unknown
Post by BrendanT123 » Tue Oct 17, 2023 10:24 am
Glad to see I'm not the only one! Also sent my dump file on Sunday. Checking back every day to see when it comes through.
As per the response the name of the dump I received was "MKB20_v76_Willy_Wonka_and_the_Chocolate_Factory_36F7"
Post by MartyMcNuts » Tue Oct 17, 2023 9:40 pm
Guys, when posting, please include the name of your dump file. This is so others can check these threads before they send in their dump as there's little point in emailing the same dump file again.
sashieden
Post by sashieden » Tue Oct 17, 2023 11:42 pm
BrendanT123
Post by BrendanT123 » Fri Oct 20, 2023 1:08 am
Volume Key Unknown error "MKB20_v76_Willy_Wonka_and_the_Chocolate_Factory_36F7" has been fixed in latest HK download.
cadalyst97
Post by cadalyst97 » Thu Oct 26, 2023 11:07 pm
Same issue
MakeMKV v1.17.5 win(x64-release) started
Using LibreDrive mode (v06.3 id=4083C4CCDB14)
Downloading latest HK to ...
Saved AACS dump file as .../MKB20_v76_Willy_Wonka_and_the_Chocolate_Factory_36F7.tgz
Post by Woodstock » Fri Oct 27, 2023 12:56 am
You need to find out what's blocking you from doing downloads. Probably your DNS. There are message topics about this.
