makemkv was prevented from modifying apps on your mac
Aliu10
#1 Post by Aliu10 » Sun Oct 15, 2023 12:28 am
How do i fix this, it keeps switching off
Im using a Sonoma
Re: makemkv was prevented from modifying apps on your mac
#2 Post by Woodstock » Sun Oct 15, 2023 12:56 am
MakeMKV does not generally modify apps on your system. Knowing what feature of your system is thinking that it is doing so would be helpful.
reinforcer
#3 Post by reinforcer » Mon Oct 16, 2023 8:54 am
I'm having the same issue. I cannot integrate makemkv into VLC or handbrake because macos keeps blocking the integration.
I did enable "makemkv" and "MakeMkv" but its always resetting the security setting.
#4 Post by dcoke22 » Mon Oct 16, 2023 7:15 pm
Are you granting MakeMKV full disk access in the Privacy & Security tab of System Settings/System Preferences?
https://support.apple.com/guide/mac-hel ... 0/mac/13.0
reinforcer
#5 Post by reinforcer » Mon Oct 23, 2023 12:09 pm
Yes I did.
#6 Post by dcoke22 » Mon Oct 23, 2023 5:43 pm
I'm not running macOS 14 Sonoma, so I haven't experienced your issue. I wonder if Sonoma has bug?
#7 Post by dcoke22 » Mon Oct 23, 2023 9:44 pm
A little internet searching has shown that all kinds of apps with legitimate needs for full disk access seem to be having problems with Sonoma at the moment.
cinemaslavejoe
#8 Post by cinemaslavejoe » Sun Dec 03, 2023 1:40 am
Exact same problem here. I just spent an hour banging my head on the desk trying to figure out why I can't get this working before I decided to search the forum.
I'm running Sonoma on a Mac M3 Max. I can rip 4K UHDs fine using MakeMKV, but I can't enable the decryption for VLC. Every time I go to Preferences > Integration and check the VLC box, it tells me this action was blocked and asks me if I want to allow it. I click Yes. I then launch VLC, and I can watch as the checkbox unselects itself. I then get the usual error about how there's no AACS library. Repeat over and over and over.
Definitely seems to be a Sonoma thing. Anyone found a solution yet?
yannisgk
#9 Post by yannisgk » Sat Dec 16, 2023 2:18 am
same here . it's the usual tactic (as i believe) of apple to not allow any software to fight their overall strategy (in this situation, to use a locked bluray disc to be played without paying!!!).
makemkv developers save us!!!
#10 Post by dcoke22 » Sat Dec 16, 2023 6:44 pm
MacOS allows virtualizing macOS now… I wonder if someone on Sonoma also has something like Parallels Desktop for Mac. You could try setting up a VM with an older MacOS, like Ventura or Monterey, and see if MakeMKV works any better.
There are a bunch of things I don't know. Normally, new Macs can not run older versions of macOS than what they originally shipped with. If you have a M3 Mac, it must run Sonoma or later. The hardware drivers necessary for the M3 chips don't exist in older versions of macOS. I have no idea if this also applies in a virtualized environment.
Also, I don't know how well MakeMKV will work with optical drives through a VM. Generally speaking, MakeMKV needs pretty low level access to the optical drive to do its work.
I'm not on Sonoma yet and I haven't tried any of the above. But if the troubles with Sonoma are because of a Sonoma bug, trying to use an older macOS in a VM might be a way to work around it. If someone happens to have the right software and is feeling adventurous, perhaps they can give it a try and let us know.
iamschott
#11 Post by iamschott » Wed Jan 17, 2024 3:07 pm
I don't ever get this integration to work ever not in Sonoma or prior. Every now and then I come to check if it ever got fixed but it never did. It does provide a dialog box to enable as if it would actually allow to change it. But my experience is it would automatically uncheck in an infinite loop purposely to drive you crazy. From this post it seems like it worked before but not my experience ever.
iamschott
#12 Post by iamschott » Fri Jan 19, 2024 9:51 pm
i found a solution or workaround on reddit entitled "Bug regarding macOS Ventura and MakeMKV Decryption Integration with VLC" and it worked.
JUST want to give an update here. So after I found some closure with this issue.
adamschoales
#13 Post by adamschoales » Wed Feb 14, 2024 9:37 pm
Add me to the chorus of people who cannot get the integration to work in Sonoma.
Had no issues on other machines prior to Sonoma, but got a new M3 Max so Sonoma was the default installed OS. Tried setting up Handbrake integration and have the same problem as everyone else here. Hopefully there's a solution...
jdwarwick
#14 Post by jdwarwick » Fri Mar 15, 2024 8:14 am
Enabling the check box as root worked for me:
1-Open a Terminal window and type "sudo"
2-Control or right click on the MakeMKV app and select "Show package contents
3-Go to Mac OS folder and select the "makemkv" executable
4- Drop it into the Terminal window, hit return and enter your password
You should now be able to go to "Privacy & Security", select "App Management" and enable both "makemkv" and "MakeMKV". Then, in the integrations tab of MakeMKV you should be able to enable the integration.
Quit MakeMKV and reopen and the setting should have stuck.
Powerkey
#15 Post by Powerkey » Tue Apr 09, 2024 5:02 am
That did not work for me.
Whenever I select Handbrake, I get a notification that makemkv was blocked and the item in Application Management is switched off. I tried adding it while the root-launched application was still running and also after a quit and relaunch. The Application Management switch always disables itself.
I also tried removing all references to MakeMKV in Settings -> Privacy & Security and starting over.
