WinterSoldierUK
Re: SDFtool Flasher
Post by WinterSoldierUK » Thu Oct 12, 2023 7:49 am
MartyMcNuts wrote: Wed Oct 11, 2023 10:22 pm
WinterSoldierUK wrote: Wed Oct 11, 2023 7:50 am
MartyMcNuts wrote: Tue Oct 10, 2023 10:30 pm
Not sure what this drive is. What is the model?
Here's an Amazon link, has pictures of the serials etc.
Hitachi-LG BP55 External Blu-Ray Drive, USB 2.0 Slim Portable Player/Rewriter for Laptop, Desktop PC, Windows 11 Compatible, with TV Connectivity, 3D Playback, 8x Read/Write Speed - Black https://amzn.eu/d/0aUDePF
It's flashable to my knowledge just not sure what the correct firmware is.
That's a BP55EB40. If you said that, I would have known what it was. The recommended firmware is BU40N 1.00, which will work with all popular ripping software. The flashing process may differ, depending on how new the drive is. It should have a SVC code written underneath and also on the side of the box where the model / manufacture date is. Let me know the manufacture date and the SVC code and I can advise further,
My bad - Manufactured May 2023 SVC is EB52.
Re: SDFtool Flasher
Post by MartyMcNuts » Thu Oct 12, 2023 9:31 pm
WinterSoldierUK wrote: Thu Oct 12, 2023 7:49 am
You can follow the same process as the BP50NB40 SVC NB52 in the first post. I think there's a BP55EB40 1.03-MK firmware in either my firmware pack or the MK firmware pack, use it instead of the BP50NB40 1.03-MK firmware. Use the BU40N 1.00 firmware as your final firmware in the recovery step.
WinterSoldierUK
Re: SDFtool Flasher
Post by WinterSoldierUK » Fri Oct 13, 2023 7:19 am
MartyMcNuts wrote: Thu Oct 12, 2023 9:31 pm
Swing and a miss but at least I didn't brick the drive. I used the 1.03MK that is in the MK pack and then applied the basic BU40N 1.00 (even though there are higher versions). Reads blus still but not 4K UHDs. Note that the BU40N is from your pack as MK doesnt have 1.00 - have I crossed the streams by using Firmwares from 2 different packs?
Re: SDFtool Flasher
Post by Billycar11 » Fri Oct 13, 2023 8:12 am
WinterSoldierUK wrote: Fri Oct 13, 2023 7:19 am
what bu40n did you flash some dont do UHD
Re: SDFtool Flasher
Post by MartyMcNuts » Fri Oct 13, 2023 9:24 am
Did you use the BU40N 1.00 firmware in the recovery step? Show us your drive's MakeMKV info panel.
WinterSoldierUK
Re: SDFtool Flasher
Post by WinterSoldierUK » Fri Oct 13, 2023 10:08 am
Billycar11 wrote: Fri Oct 13, 2023 8:12 am
DE_LG_BU40N_1.00.bin - there is a DE_LG_BU40N_1.03_MK.bin but Marty said to use 1.00
WinterSoldierUK
Re: SDFtool Flasher
Post by WinterSoldierUK » Fri Oct 13, 2023 10:11 am
MartyMcNuts wrote: Fri Oct 13, 2023 9:24 am
OS device name: J:
Current profile: DVD-ROM
Product: BD-RE BP55EB40
Revision: 1.03
Serial number: SIK09N5VC1245
Firmware date: 2120-05-07 09:24
Highest AACS version: 63
Firmware version: 1.03
Re: SDFtool Flasher
Post by MartyMcNuts » Fri Oct 13, 2023 11:02 am
WinterSoldierUK wrote: Fri Oct 13, 2023 10:11 am
OS device name: J:
Revision: 1.03
You haven't done the second part of the process.
In SDFtool Flasher, select your drive, select recovery option, in the popup, select the BP55 firmware that you have already flashed to the drive, in the firmware drop down, select the BU40N 1.00 firmware and click START.
WinterSoldierUK
Re: SDFtool Flasher
Post by WinterSoldierUK » Fri Oct 13, 2023 11:10 am
MartyMcNuts wrote: Fri Oct 13, 2023 11:02 am
OS device name: J:
Revision: 1.03
Dammit I missed the popup part and the fact that you had to point it to the burnt firmware. All works perfectly now - thank you so much for the support! I'm normally more technical than this :)
HomeTheatreGuy
Re: SDFtool Flasher
Post by HomeTheatreGuy » Thu Nov 02, 2023 10:40 pm
I have an Archgon MD-8107-U3 that MakeMKV sees as
OS device name: F:
Product: BD-RE BU40N
Revision: 1.01
Serial number: MOCJ7AG3720
Firmware date: 2117-12-22 12:21
Bus encryption flags: 1F
Highest AACS version: 72
I downloaded the new SDFTool flasher and I just have a question on the image to use... From the All You Need Firmware Pack (MartyMcNuts) pack I see 2 .bin files that I could use
  • DE_LG_BU40N_1.00.bin
  • DE_LG_BU40N_1.03_MK.bin
Not sure which one to use to flash. I read on a threat about this very drive with the exact revision and firmware that either could be used...
Any thoughts?
Thank you in advanced!!!!
Re: SDFtool Flasher
Post by MartyMcNuts » Fri Nov 03, 2023 12:54 am
HomeTheatreGuy wrote: Thu Nov 02, 2023 10:40 pm I have an Archgon MD-8107-U3 that MakeMKV sees as
OS device name: F:
Revision: 1.01
Any thoughts?
As your drive is on older unencrypted firmware, you should be able to directly flash to BU40N 1.00. It is the recommended firmware and works with all popular ripping software.
HomeTheatreGuy
Re: SDFtool Flasher
Post by HomeTheatreGuy » Sat Nov 04, 2023 3:40 pm
Worked! Thanks!
I purchased MakeMKV a while back but would still love to donate to the project.... How would one do that?
Re: SDFtool Flasher
Post by d00zah » Sat Nov 04, 2023 7:32 pm
HomeTheatreGuy wrote: Sat Nov 04, 2023 3:40 pm Worked! Thanks!
https://www.makemkv.com/buy/
MikeReloaded
[SOLVED] Re: SDFtool Flasher
Post by MikeReloaded » Wed Nov 08, 2023 7:30 pm
I downloaded and tried the SDFtool and I get a .net exception error on any machine when I try to use it. I am up to date on all the different updates of .net.
I have searched and not found anything here. Is anyone else experiencing this?
[Found out I needed to have the MakeMKV installed also for it to not have that error I mentioned. It does say MakeMKV is a requirement in the tutorial, but doesn't say that the firmware update tool won't run without it.] :roll:
Re: [SOLVED] Re: SDFtool Flasher
Post by MartyMcNuts » Wed Nov 08, 2023 10:50 pm
MikeReloaded wrote: Wed Nov 08, 2023 7:30 pm I downloaded and tried the SDFtool and I get a .net exception error on any machine when I try to use it. I am up to date on all the different updates of .net.
Of course it won't run without it!! SDFTool Flasher is a "frontend GUI" for MakeMKV's built in command line.
