The Wicker Man 4k - dump submitted
Pete B
Re: The Wicker Man 4k - dump submitted
Post by Pete B »
Just chiming in that I'm in the same boat; still no joy with the Studio Canal second disc containing the Theatrical Cut.
BrianDW
Post by BrianDW »
It's been 3 weeks since the first dump was submitted, and nothing.
This seems to be much longer than normal. is something going on we don't know about?
Pete B
Post by Pete B »
Heeeeeeey-hoooooo, who is there?
No updated keys, my dear.
Pete B wrote: Fri Oct 13, 2023 2:06 am Heeeeeeey-hoooooo, who is there?
post the disc info from makemkv is it a aacs 2.1 disc? if so the wait may be alot longer
Pete B
Post by Pete B »
Billycar11 wrote: Fri Oct 13, 2023 4:05 am
Hi. Thanks for the reply.
Here is the disc info:
Disc Information
Label: THE_WICKER_MAN_DISC2
Timestamp: 2023-08-14 15:19:29
Protection: AACS2.0/C v70
Data capacity: 92.52 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
... and here is the error info:
MakeMKV v1.17.5 win(x64-release) started
Using LibreDrive mode (v06.3 id=4ACF8047C3AC)
Saved AACS dump file as C:\Users\I DELETED THE INFO THAT WAS HERE FROM THE FILE PATH/.MakeMKV/MKB20_v70_The_Wicker_Man_-_Disc_2_1ABF.tgz
Just let me know if posting any further info may help.
Pete B wrote: Fri Oct 13, 2023 9:29 pm
Disc Information
Number of layers: 3
It's a standard aacs 2.0 should work in a week or 2 if you submitted the dump and your hk downloads work
Pete B
Post by Pete B »
Billycar11 wrote: Sat Oct 14, 2023 12:06 am
Disc Information
Number of layers: 3
Groovy, thanks for letting me know. I'm in New Zealand and we're usually last to get a 4K release so everything usually rips right out of the gate as dumps have usually been made by someone else in the world. I shall sit tight.
Pete B
Post by Pete B »
In the 70's they made a film... and a fine, fine film was he.
And from that film, a 4K scan.
And from that scan, there were some files
And on a disc, they burned those files.
And on a plane, they sent that disc.
And from that disc, they tried to rip.
And from that rip, a error came.
And of that error a t... gz.
And they submitted, submitted, submitted, submitted...
Pete B
Post by Pete B »
The rip did not fail!
Successfully backed up the Theatrical Cut from the Studio Canal Disc 2 after a HK update. Interestingly, the artwork makes no mention of Dolby Vision but there's a MEL in there.
Thanks for getting the thing done so the thing works now.
BrianDW
Post by BrianDW »
Still no luck with the final cut. No problems with theatrical / DC.
Maybe my disc is bad? Anyone able to back up the 4K FC?
BrianDW wrote: Fri Oct 20, 2023 11:54 pm Still no luck with the final cut. No problems with theatrical / DC.
did you get a volume key unknow error or a read error?
BrianDW
Post by BrianDW »
I get nothing. The disc starts decrypting / opening and then stops, as the "time remaining" increases while the disc sputters.
Note the disc plays perfectly. No issues at all. On my PC and a standalone 4k player.
Its clean, and other 4Ks using the same drive work without issue using MAKEmkv.
Checking torrent sites (only out of curiosity, of course!) I have noticed NO 4K remux of the Final Cut are posted, while torrents for the DC and Extended cut 4K's are posted.
The disc just sits in my drive, Make MKV does not stop, as with an unknown volume K or read error. It just keeps adding to the remaining time count while the decrypting / opening progress bars stay in the same place.
BrianDW wrote: Sat Oct 21, 2023 2:51 pm I get nothing. The disc starts decrypting / opening and then stops, as the "time remaining" increases while the disc sputters.
That's a bad disc or drive
Clean the disc
Replace the disc
Clean the drive
Replace the drive with a pioneer
BrianDW
Post by BrianDW »
As stated, - The "bad" disc plays in the "bad" drive on my PC. The "Bad" disc pays on my 4K player.
THE disc, as I wrote is clean. The drive is clean. The "bad" drives decrypts other 4K discs without issue.
Why would you respond to my post, which you obviously did not read?
BrianDW wrote: Sat Oct 21, 2023 9:55 pm As stated, - The "bad" disc plays in the "bad" drive on my PC. The "Bad" disc pays on my 4K player.
Just because it works in a regular blu-ray player does not mean it's good for your UHD drove some discs are annoying In some drives.
Seen this many times a new disc or cleaning the disc will likely help
