Mission: Impossible UHD - Fails to Rip with Scsi and OS Errors
Silo4148
Post by Silo4148 »
Purchased a like new (opened, never viewed) Mission: Impossible 6 movie set on eBay. The first UHD disc fails at about 30% rip progress each time with read errors (pasted below). There is one small spot on the disc that looks like a permanent smudge or warp of some sort (photos attached). All the other discs seem fine. I know defects are rare, but I can't imagine what else the issue could be. I'm using the latest MakeMKV 1.17.5 on Windows 10 with a pre-flashed Pioneer XS07S that I purchased from Billy on this forum. Every other UHD disc I've thrown at it has worked.
I'm trying to work with the eBay seller. I know it's not their fault, but at the end of the day I still received what seems to be a defective disc. I have a scratch repair kit that I could possibly try as a last ditch effort. I've done a gentle cleaning and wipe down twice already. Any suggestions?
Using LibreDrive mode (v01.0 id=1534D764B687)
Title #00020.mpls has length of 208 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00073.mpls has length of 14 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00035.mpls has length of 110 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00108.mpls has length of 21 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00106.mpls has length of 14 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00103.mpls has length of 14 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00104.mpls has length of 14 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00107.mpls has length of 14 seconds which is less than minimum title length of 300 seconds and was therefore skipped
File 00800.mpls was added as title #0
Title #00026.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00025.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00024.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00001.m2ts has length of 5 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00005.m2ts has length of 208 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00054.m2ts has length of 11 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00029.m2ts has length of 11 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00060.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00055.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00058.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00057.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00027.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00023.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00002.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00129.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00000.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00010.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00004.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00030.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00147.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00146.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00145.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00144.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00022.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00143.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00017.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00142.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00021.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00141.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00020.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00140.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00019.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00139.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00008.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00138.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00016.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00137.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00015.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00136.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00014.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00135.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00013.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00134.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00012.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00133.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00132.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00131.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00130.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00006.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00128.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00127.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00126.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00125.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00124.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00123.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00122.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00121.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00120.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00119.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00118.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00117.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00116.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00115.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00114.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00113.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00112.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00111.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00110.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00109.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00108.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00107.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00106.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00105.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00104.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00103.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00102.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00011.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00009.m2ts has length of 1 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00007.m2ts has length of 16 seconds which is less than minimum title length of 300 seconds and was therefore skipped
File 00018.m2ts was added as title #1
Title #00028.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Saving 1 titles into directory M:/Rips/Movies/Mission- Impossible
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14529589248'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '14529589248'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14530314240'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14531690496'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '14531690496'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14534768640'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14537521152'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14537846784'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '14537846784'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14537914368'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14538571776'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '14538571776'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14538897408'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '14538897408'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14539290624'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '14539290624'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14540273664'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '14540273664'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14540992512'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14541324288'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '14541324288'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14542368768'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '14542368768'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14542700544'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '14542700544'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14543026176'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '14543026176'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14543745024'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '14543745024'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14544076800'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14544402432'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '14544402432'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00018.m2ts' at offset '14546497536'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '14546497536'
Failed to save title 0 to file M:/Rips/Movies/Mission- Impossible/Mission- Impossible_t00.mkv
Encountered 59 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Re: Mission: Impossible UHD - Fails to Rip with Scsi and OS Errors
Those errors indicate the drive could not correctly read part of the disc.
I like to clean discs using plenty of water and liquid dish soap. I lightly move my finger tip from the inner edge to the out edge and back again, perpendicularly. After cleaning all the way around the disc, I throughly rinse, set the label side down on a towel and dry the data side with a can of air, thereby minimizing how much I have to touch the disc.
Bly-ray.com indicates that Mission: Impossible - Fallout (2018) is a triple-layer BD-100 disc. Those are the hardest discs to rip as the data density of the disc is the highest of any blu-ray.
As good as Pioneer drives are, sometimes different drives give different results for the same disc. If you have access to other optical drives, it wouldn't hurt to try this disc in those drives.
In the end, you might have a bad disc. If gentle cleaning doesn't work and if you can't get the disc exchanged, I think your only options might be to get a new disc or try some 'extreme' cleaning methods. I don't recommend the extreme cleaning, but the internet is full of people who claim 'one weird trick' made an unreadable disc work for them.
