MKB20_v77_TRANSFORMERS_RISE_OF_BEASTS_92D0 Sent
As per title.
Sent MKB20_v77_TRANSFORMERS_RISE_OF_BEASTS_92D0
Re: MKB20_v77_TRANSFORMERS_RISE_OF_BEASTS_92D0 Sent
Awesome. Hoping to have mine on Tuesday most likely.
Dump sent for Aussie UHD version.
MKB20_v77_TRANSFORMERS_RISE_OF_BEASTS_DF22
Mine was supported. Hopefully it works for some of you now.
Nope, mine is still not working.
MKB20_v77_Transformers-_Rise_of_the_Beasts_ADC6.tgz
That's my supported version. I never had to submit it.
Can confirm this one is working now.
Are you also seeing the following?
Fixing Volume Key is UnknownLoaded content hash table, will verify integrity of M2TS files.
Downloading latest HK to C:\Users\xxxxxxxxx/.MakeMKV ...
I do not get the downloading latest HK message. I am on a Mac and wondering if it is blocking the download. It was a PITA installing as it really didn't want to let me. I do have Access Internet enabled in the settings.d00zah wrote: ↑Sun Oct 15, 2023 5:08 pmAre you also seeing the following?Fixing Volume Key is UnknownLoaded content hash table, will verify integrity of M2TS files.
Is this your 1st UHD attempt? Is your optical drive UHD capable/LibreDrive enabled? If in doubt, pls copy/paste/post the complete MakeMKV Info pane contents (upper, right).
no, I have ripped other UHD titles before. it is LibreDrive enabled - I can see it in the info section. This happened when I updated to the latest version on the Mac. Also now on Sonoma so don't know if that matters.
It doesn't seem to be downloading the last info to decrypt.
But it's also not reporting that it tried to and/or failed?casey737 wrote: ↑Sun Oct 15, 2023 6:02 pmno, I have ripped other UHD titles before. it is LibreDrive enabled - I can see it in the info section. This happened when I updated to the latest version on the Mac. Also now on Sonoma so don't know if that matters.
This is what I get.d00zah wrote: ↑Sun Oct 15, 2023 6:06 pmBut it's also not reporting that it tried to and/or failed?casey737 wrote: ↑Sun Oct 15, 2023 6:02 pmno, I have ripped other UHD titles before. it is LibreDrive enabled - I can see it in the info section. This happened when I updated to the latest version on the Mac. Also now on Sonoma so don't know if that matters.
MakeMKV v1.17.5 darwin(arm64-release) started
Optical drive "BD-RE PIONEER BD-RW BDR-XD07U 1.03 BDDL012508UCd" opened in OS access mode.
Using LibreDrive mode (v01.0 id=27184B96DBEE)
Saved AACS dump file as /Users/keithwinand/Library/MakeMKV/MKB20_v77_Transformers-_Rise_of_the_Beasts_ADC6.tgz
Drive Informationcasey737 wrote: ↑Sun Oct 15, 2023 6:10 pmThis is what I get.d00zah wrote: ↑Sun Oct 15, 2023 6:06 pmBut it's also not reporting that it tried to and/or failed?casey737 wrote: ↑Sun Oct 15, 2023 6:02 pmno, I have ripped other UHD titles before. it is LibreDrive enabled - I can see it in the info section. This happened when I updated to the latest version on the Mac. Also now on Sonoma so don't know if that matters.
OS device name: /dev/rdisk5
Manufacturer: PIONEER
Product: BD-RW BDR-XD07U
Revision: 1.03
Serial number: BDDL012508UC
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 77
Drive platform: RS8D31
Firmware version: 1.03/ID05
Disc Information
Label: TRANSFORMERS_RISE_OF_BEASTS
Timestamp: 2023-07-28 10:14:50
Protection: AACS2.0/C v77
Data capacity: 3683.90 Gb
Bus encryption flags: 80
