MKB20_v77_TRANSFORMERS_RISE_OF_BEASTS_92D0 Sent
ictbydesign
#1 Post by ictbydesign » Sat Oct 07, 2023 4:39 pm
As per title.
Sent MKB20_v77_TRANSFORMERS_RISE_OF_BEASTS_92D0
Re: MKB20_v77_TRANSFORMERS_RISE_OF_BEASTS_92D0 Sent
#2 Post by SamuriHL » Sat Oct 07, 2023 6:28 pm
Awesome. Hoping to have mine on Tuesday most likely.
#3 Post by MartyMcNuts » Mon Oct 09, 2023 2:04 am
Dump sent for Aussie UHD version.
MKB20_v77_TRANSFORMERS_RISE_OF_BEASTS_DF22
#4 Post by SamuriHL » Tue Oct 10, 2023 7:08 pm
Mine was supported. Hopefully it works for some of you now.
#5 Post by MartyMcNuts » Wed Oct 11, 2023 10:56 pm
Nope, mine is still not working.
#6 Post by SamuriHL » Wed Oct 11, 2023 11:14 pm
MKB20_v77_Transformers-_Rise_of_the_Beasts_ADC6.tgz
That's my supported version. I never had to submit it.
ictbydesign
#7 Post by ictbydesign » Sat Oct 14, 2023 7:25 am
Can confirm this one is working now.
casey737
#8 Post by casey737 » Sun Oct 15, 2023 4:31 pm
I have this same version and it is not working - "The volume key is unknown for this disc - video can't be decrypted"
#9 Post by d00zah » Sun Oct 15, 2023 5:08 pm
Are you also seeing the following?
Downloading latest HK to C:\Users\xxxxxxxxx/.MakeMKV ...
Fixing Volume Key is Unknown
casey737
#10 Post by casey737 » Sun Oct 15, 2023 5:43 pm
I do not get the downloading latest HK message. I am on a Mac and wondering if it is blocking the download. It was a PITA installing as it really didn't want to let me. I do have Access Internet enabled in the settings.
#11 Post by d00zah » Sun Oct 15, 2023 5:51 pm
Is this your 1st UHD attempt? Is your optical drive UHD capable/LibreDrive enabled? If in doubt, pls copy/paste/post the complete MakeMKV Info pane contents (upper, right).
casey737
#12 Post by casey737 » Sun Oct 15, 2023 6:02 pm
no, I have ripped other UHD titles before. it is LibreDrive enabled - I can see it in the info section. This happened when I updated to the latest version on the Mac. Also now on Sonoma so don't know if that matters.
It doesn't seem to be downloading the last info to decrypt.
#13 Post by d00zah » Sun Oct 15, 2023 6:06 pm
But it's also not reporting that it tried to and/or failed?
casey737
#14 Post by casey737 » Sun Oct 15, 2023 6:10 pm
This is what I get.
MakeMKV v1.17.5 darwin(arm64-release) started
Optical drive "BD-RE PIONEER BD-RW BDR-XD07U 1.03 BDDL012508UCd" opened in OS access mode.
Using LibreDrive mode (v01.0 id=27184B96DBEE)
Saved AACS dump file as /Users/keithwinand/Library/MakeMKV/MKB20_v77_Transformers-_Rise_of_the_Beasts_ADC6.tgz
casey737
#15 Post by casey737 » Sun Oct 15, 2023 6:12 pm
This is what I get.
OS device name: /dev/rdisk5
Manufacturer: PIONEER
Product: BD-RW BDR-XD07U
Revision: 1.03
Serial number: BDDL012508UC
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 77
Drive platform: RS8D31
Firmware version: 1.03/ID05
Disc Information
Label: TRANSFORMERS_RISE_OF_BEASTS
Timestamp: 2023-07-28 10:14:50
Protection: AACS2.0/C v77
Data capacity: 3683.90 Gb
Bus encryption flags: 80
