MKB20_v77_TRANSFORMERS_RISE_OF_BEASTS_92D0 Sent
ictbydesign
Post by ictbydesign »
As per title.
Sent MKB20_v77_TRANSFORMERS_RISE_OF_BEASTS_92D0
Re: MKB20_v77_TRANSFORMERS_RISE_OF_BEASTS_92D0 Sent
Post by SamuriHL »
Awesome. Hoping to have mine on Tuesday most likely.
Dump sent for Aussie UHD version.
MKB20_v77_TRANSFORMERS_RISE_OF_BEASTS_DF22
Post by SamuriHL »
Mine was supported. Hopefully it works for some of you now.
Nope, mine is still not working.
Post by SamuriHL »
MKB20_v77_Transformers-_Rise_of_the_Beasts_ADC6.tgz
That's my supported version. I never had to submit it.
ictbydesign
Can confirm this one is working now.
casey737
Post by casey737 »
SamuriHL wrote:
Wed Oct 11, 2023 11:14 pm
I have this same version and it is not working - "The volume key is unknown for this disc - video can't be decrypted"
Post by d00zah »
casey737 wrote:
Sun Oct 15, 2023 4:31 pm
Are you also seeing the following?
Downloading latest HK to C:\Users\xxxxxxxxx/.MakeMKV ...
Fixing Volume Key is Unknown
casey737
Post by casey737 »
d00zah wrote:
Sun Oct 15, 2023 5:08 pm
I do not get the downloading latest HK message. I am on a Mac and wondering if it is blocking the download. It was a PITA installing as it really didn't want to let me. I do have Access Internet enabled in the settings.
Post by d00zah »
casey737 wrote:
Sun Oct 15, 2023 5:43 pm
Is this your 1st UHD attempt? Is your optical drive UHD capable/LibreDrive enabled? If in doubt, pls copy/paste/post the complete MakeMKV Info pane contents (upper, right).
casey737
Post by casey737 »
d00zah wrote:
Sun Oct 15, 2023 5:51 pm
no, I have ripped other UHD titles before. it is LibreDrive enabled - I can see it in the info section. This happened when I updated to the latest version on the Mac. Also now on Sonoma so don't know if that matters.
It doesn't seem to be downloading the last info to decrypt.
Post by d00zah »
casey737 wrote:
Sun Oct 15, 2023 6:02 pm
But it's also not reporting that it tried to and/or failed?
casey737
Post by casey737 »
d00zah wrote:
Sun Oct 15, 2023 6:06 pm
This is what I get.
MakeMKV v1.17.5 darwin(arm64-release) started
Optical drive "BD-RE PIONEER BD-RW BDR-XD07U 1.03 BDDL012508UCd" opened in OS access mode.
Using LibreDrive mode (v01.0 id=27184B96DBEE)
Saved AACS dump file as /Users/keithwinand/Library/MakeMKV/MKB20_v77_Transformers-_Rise_of_the_Beasts_ADC6.tgz
casey737
Post by casey737 »
casey737 wrote:
Sun Oct 15, 2023 6:10 pm
This is what I get.
OS device name: /dev/rdisk5
Manufacturer: PIONEER
Product: BD-RW BDR-XD07U
Revision: 1.03
Serial number: BDDL012508UC
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 77
Drive platform: RS8D31
Firmware version: 1.03/ID05
Disc Information
Label: TRANSFORMERS_RISE_OF_BEASTS
Timestamp: 2023-07-28 10:14:50
Protection: AACS2.0/C v77
Data capacity: 3683.90 Gb
Bus encryption flags: 80
