Three Musketeers bluray rip will not play
GoodBoy
Post by GoodBoy » Tue Oct 10, 2023 4:29 pm
This is the bluray disc from the 3D Bluray+Bluray version of The Three Musketeers.
Using MakeMKV 1.17.5
Drive is wh16ns40 flashed to wh16ns60 1.02
The backup went without error.
Trying to playback on a DuneHD 4k pro vision solo. It starts ok but within 5 minutes, the screen blanks and the playback jumps to a different earlier point. Let it play and it will do it again (at iirc the same point).
Looking in the stream folder, there are about 150 m2ts files.. It looks like the disc was mastered in a weird way of a bunch of small pieces... playing these its clear they are not sequential. The largest piece is 2.6Gb and is an 11 minute chunk.
Issue with how the DuneHD is playing it back? It loads the disc menu so would think it would read the playlist and know the order to play the m2ts files..
Edit: Ok, figured out that this is a obfuscated playlist. Another post mentions 00437.mpls as the possible proper one, disc came out in multiple versions. But how do I get DuneHD to play/use that playlist?
