From what I’ve read to find the correct playlist it’s advised to search MakeMKV,Redfox,AVforums or BDinfo for discussions on the correct playlist.
There is another dated method using Process monitor along with PowerDVD to find the correct playlist.
Ripping is new to me and so is MakeMKV. When I saw too many playlists to count with this “screen pass” title I hit the forums here . I found a discussion on this title saying it’s 641 on Red and 589 on retail.
I have a retail 4K & Blu-Ray US combo and ripped 589 on the BD and the scenes were off .
I read AnyDVD HD will tell you which playlist it is but if AnyDVD HD was required so many people across the internet wouldn’t be using MakeMKV .
solely.
I installed AnyDVD HD and it said 820,202 were good playlists. Can there be more than one correct playlist?
Then I enlarged the MakeMKV window and noticed I didn’t have a 820 and already knew 589 wasn’t correct for me. Then I noticed MakeMKV automatically detected 202 as the main feature.
My question is, do I need AnyDVD HD at all to make MKV rips ? It seems MakeMKV collects correct playlist information and has updated the program to alert me automatically
Do I need to process my .mkv file to remove protections like Cinavia from my rips?
John Wick 2014 4K
Ezatoka
Re: John Wick 2014 4K
Cinavia cannot be removed. Even DVDfab only claims to be able to do so for certain language tracks.
But... this is not a problem at all, because most software players give a shit about the cinavia protection and will ignore it. Though I cannot give you a list, which players do. "Official" players most likely won't like the Cinavia protected file.
Anything is possible. In my experience however, there's only ever one correct playlist. That said, in North America you'll often find 3 'correct' playlists on Pixar discs (for example). One will be English, one will have French opening titles/closing titles and any signs in the movie, and one will be Spanish.
There's almost always a thread here about a disc with an obfuscated playlist. It might be a bit messy, but someone has probably found the correct playlist. Finding that info in the thread is sometimes hard.
Phe0nix
Thank you. It seems MakeMKV is collecting this information and adding it to the software like I’ve read Redfox does. Am I wrong. If that’s the case I’ll only need to worry about new releases or I’ll need to buy AndDVD HD to tell me which one is correct since running process monitor with PowerDVD no long works from what I’ve readdcoke22 wrote: Tue Oct 10, 2023 10:57 pm.
Ezatoka
As much as I know, no, MakeMKV does not "collect" these informations and send them somewhere. MakeMKV just uses an installed Java and goes through the BluRay menu like a "normal" player would do. And when it selects the main title, it'll get the (mostly) correct playlist.Phe0nix wrote: Wed Oct 11, 2023 9:37 am It seems MakeMKV is collecting this information and adding it to the software like I’ve read Redfox does. Am I wrong.
I think others do it the same way, but give it fancy names like BluPath or alike.
I think in general it is only Lionsgate that has used playlist obfuscation and lately I think they've finally given up using it. I've managed to muddle along only using MakeMKV.
seamus
I am a MakeMKV newbie. I just encountered the issue that I think is under discussion here... trying to rip "John Wick" from a disk that's said to be: "4KUltraHD, BluRay, Digital HD". All I wanted was the BluRay (1920x1080). There were over 200 titles listed, they were all pre-selected, and almost all of them were the same size at 30.9 GB.
What in the world is going on?? How do I get the correct title?? ... and do I actually have to un-check over 200 titles??
I guessed. I selected the first title:
At the end, I got this:
---Title information
Comment: FPL_MainFeature
Source file name: 00202.mpls
Duration: 1:41:12
Chapters count: 16
Segment count: 20
Segment map: 508,501,503,511,510,516,520,518,507,512,519,513,509,517,515,506,514,504,502,505
File name: John Wick-FPL_MainFeature_t00.mkv
I've begun playing the movie in VLC (before I put it on the Jellyfin server), and so far it looks OK, but never having seen the movie, I'm not certain what I've got. Can someone please explain?DEBUG: Code 4194401 at fnKw7c!9v3[Q JjG:29404326
This thread might help: John Wick - US Versionseamus wrote: Tue Jul 01, 2025 12:21 am I am a MakeMKV newbie. I just encountered the issue that I think is under discussion here... trying to rip "John Wick" from a disk that's said to be: "4KUltraHD, BluRay, Digital HD". All I wanted was the BluRay (1920x1080). There were over 200 titles listed, they were all pre-selected, and almost all of them were the same size at 30.9 GB.
There are others if you search a bit.
You do not have to uncheck each title individually. You can right-click in the right spot to bring up a context menu to uncheck everything.
John Wick is a title that has playlist obfuscation or fake playlist protection. A short explanation is the disc author takes advantage of a blu-ray's seamless branching capability to create lots of playlists on a disc where most of the playlists have at least one segment out-of-order or missing from the movie. It is an attempt to make it more difficult to rip the movie. Most titles with this 'feature' have a thread on this forum with people discussing which playlist is correct.
seamus
dcoke22 wrote: Wed Jul 02, 2025 2:17 pmThis thread might help: John Wick - US Versionseamus wrote: Tue Jul 01, 2025 12:21 am I am a MakeMKV newbie. I just encountered the issue that I think is under discussion here... trying to rip "John Wick" from a disk that's said to be: "4KUltraHD, BluRay, Digital HD". All I wanted was the BluRay (1920x1080). There were over 200 titles listed, they were all pre-selected, and almost all of them were the same size at 30.9 GB.
Thanks for the detailed explanation... and for the 'rt-click' tip!
I gather that MakeMKV is now taking care of this type of obfuscation? I say that as it turned out that the correct title seems to be the first one in the list. ???
~S
Playlist obfuscation is nothing new. Been around for over a decade. If you have Java installed and MakeMKV is pointed to it (in preferences), yeah it should help with it.seamus wrote: Fri Jul 04, 2025 6:11 amdcoke22 wrote: Wed Jul 02, 2025 2:17 pmThis thread might help: John Wick - US Versionseamus wrote: Tue Jul 01, 2025 12:21 am I am a MakeMKV newbie. I just encountered the issue that I think is under discussion here... trying to rip "John Wick" from a disk that's said to be: "4KUltraHD, BluRay, Digital HD". All I wanted was the BluRay (1920x1080). There were over 200 titles listed, they were all pre-selected, and almost all of them were the same size at 30.9 GB.
~S
