Loki S1
Loki S1
Post by SamuriHL » Tue Sep 26, 2023 8:48 pm
Disc 1: MKB20_v77_MARVEL_STUDIOS'_LOKI_SEASON_1_DISC_1_C96C has been submitted. Disc 2 was already supported.
darkedgex
Re: Loki S1
Post by darkedgex » Wed Sep 27, 2023 4:21 am
Same here, also submitted the same dump.
Re: Loki S1
Post by SamuriHL » Sat Sep 30, 2023 4:01 pm
Now supported.
darkedgex
Re: Loki S1
Post by darkedgex » Sat Sep 30, 2023 4:34 pm
Nice, got mine done this morning too. :D
lfoust
Re: Loki S1
Post by lfoust » Sat Sep 30, 2023 6:50 pm
Worked for me too. Here is how the discs layed out: https://thediscdb.com/series/loki-2021/ ... edition-4k
AsaMan
Re: Loki S1
Post by AsaMan » Mon Oct 09, 2023 6:08 pm
I am still not able to rip Disc 1 but have Disk 2 done. I get the following error:
Automatic HK downloading is disabled or failed
Cannot find any real answer to the above question. I can download the sdf.bin.gz file.
Can someone share how they got disc 1 to work? Thanks.
I have had no issues with any rip previously - newly released or not. --after submitting the log, and within 2 days it will usually decrypt.
Need help, thanks.
Re: Loki S1
Post by SamuriHL » Mon Oct 09, 2023 9:27 pm
AsaMan
Re: Loki S1
Post by AsaMan » Mon Oct 09, 2023 11:08 pm
I have read that post a number of times with regards on getting the HK file:
Enable Internet access is enabled
but the big comment about fairuse.org not being used anymore but went through that debug:
asaandrews@Asas-MacBook-Pro MakeMKV % nslookup hkdata.fairuse.org
Server: 192.168.0.1
Address: 192.168.0.1#53
Non-authoritative answer:
Address: 185.84.108.20
asaandrews@Asas-MacBook-Pro MakeMKV % wget hkdata.fairuse.org/svq/sdf.dat.gz
--2023-10-09 10:55:17-- http://hkdata.fairuse.org/svq/sdf.dat.gz
Resolving hkdata.fairuse.org (hkdata.fairuse.org)... 185.84.108.20
Connecting to hkdata.fairuse.org (hkdata.fairuse.org)|185.84.108.20|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1591223 (1.5M) [application/x-gzip]
Saving to: ‘sdf.dat.gz’
sdf.dat.gz 100%[===============================================================================>] 1.52M 317KB/s in 5.2s
2023-10-09 10:55:23 (298 KB/s) - ‘sdf.dat.gz’ saved [1591223/1591223]
The messages I have is:
003338:0000 Downloading latest HK to /Users/asaandrews/Library/MakeMKV ...
001003:0020 DEBUG: Code 4279336995 at CJo)^yl[\ob'%)d:121262877
001003:0020 DEBUG: Code 0 at )Sk0=`x9vK.<!TEW:29400163
003339:0000 Automatic HK downloading is disabled or failed.
003332:0000 Saved AACS dump file as file:///Users/asaandrews/Library/MakeMKV/MKB20_v77_MARVEL_STUDIOS'_LOKI_SEASON_1_DISC_1_C96C.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at wOavELqC2=E/?z0D:213132721
001003:0020 DEBUG: Code 0 at wOavELqC2=E/?z0D:213131341
Re: Loki S1
Post by dcoke22 » Tue Oct 10, 2023 2:23 am
There's also this recent discussion: viewtopic.php?f=12&t=30612
dawg_ripper
Re: Loki S1
Post by dawg_ripper » Tue Oct 10, 2023 1:57 pm
AsaMan, you're likely running into the same problem I had. Something on your machine is blocking access to the HK file. that fairuse address is not in use anymore. hkdata.crabdance.com is active ( at least for me )
I ended up having to temporarily stopping all protection and restarted my machine, then i was able to download the HK file, then turn back on the protection.
Hope this helps!
