Dump file from M3GAN 4K disc in BB steelbook is in the following Google Drive link. I tried to attach it, but got a "Sorry, the board attachment quota has been reached" message.
https://drive.google.com/file/d/1UY8Afo ... sp=sharing
M3GAN 4k
Re: M3GAN 4k
And you plan on emailing it to svq@makemkv.com for processing when?
chrispgriffin
Re: M3GAN 4k
Sorry about that. Just sent it over.
chrispgriffin
Re: M3GAN 4k
I've tried ripping the main feature multiple times, but I keep getting the following errors about halfway or so through:
Product: BD-RE WH16NS60
Revision: 1.03
Serial number: KLSL5A91317
Firmware date: 2120-05-08 10:10
Highest AACS version: 78
Firmware version: 1.03
- Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '9840789504'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00483.m2ts' at offset '9840789504'
Revision: 1.03
Re: M3GAN 4k
This is a read error.chrispgriffin wrote: ↑Tue Oct 10, 2023 2:07 pmI've tried ripping the main feature multiple times, but I keep getting the following errors about halfway or so through:
Here is my device and LibreDrive info:
Revision: 1.03
Clean the disc
Replace the disc
Clean the drive laser by taking it apart.
Replace drive with a pioneer
MSCloude115
Re: M3GAN 4k
Just a heads up…tried ripping the unrated cut and there was an audio drop out (right after manager leaves room after seeing Megan). I ripped it twice after cleaning the disc with the same issue. Placed the disc in my ub820 and realized that it’s a branched scene. So I placed the disc back in my computer and ripped the pg-13 version without issue. Is anyone else having this issue?
chrispgriffin
Re: M3GAN 4k
Huh, good to know. Once I get my drive issue resolved and ripped I'll give it a look.MSCloude115 wrote: ↑Wed Oct 11, 2023 2:12 amJust a heads up…tried ripping the unrated cut and there was an audio drop out (right after manager leaves room after seeing Megan). I ripped it twice after cleaning the disc with the same issue. Placed the disc in my ub820 and realized that it’s a branched scene. So I placed the disc back in my computer and ripped the pg-13 version without issue. Is anyone else having this issue?
chrispgriffin
Re: M3GAN 4k
Not sure if this is helpful at all, but I wasn't able to replicate the issue after ripping the unrated cut.MSCloude115 wrote: ↑Wed Oct 11, 2023 2:12 amJust a heads up…tried ripping the unrated cut and there was an audio drop out (right after manager leaves room after seeing Megan). I ripped it twice after cleaning the disc with the same issue. Placed the disc in my ub820 and realized that it’s a branched scene. So I placed the disc back in my computer and ripped the pg-13 version without issue. Is anyone else having this issue?
