Iam2smart
#8971 Post by Iam2smart » Mon Oct 02, 2023 12:55 am
Ill just leave it be then Thanks for the Reply
onlysleeping23
#8972 Post by onlysleeping23 » Mon Oct 02, 2023 7:08 pm
So I’ve been ripping discs in my collection, adding audio tracks, then remuxing back to usb flash drives in bdmv format for chapter support, only retaining the main feature for playback on my x800m2.
Following directions for option 2 of the x800m2 in the dolby vision stuff sheet, and using tsmuxer nightly in order to keep dolby vision, I notice if I remux the playlist file to bdmv, mediainfo shows two streams, neither listing dv.
If I remux the m2ts file, I now see dv in mediainfo, as expected.
If I then remux the new m2ts back to bdmv, mediainfo no longer shows dolby vision.
Am I doing something wrong? Should I only remux to m2ts to keep dolby vision, and manually place it in the bdmv structure?
Would really appreciate any advice/help!
#8973 Post by RESET_9999 » Wed Oct 04, 2023 2:06 pm
@onlysleeping23 it's normal and look at an original DV BD folder , you'll see that it's the same.
chronomac
#8974 Post by chronomac » Wed Oct 04, 2023 3:30 pm
I think I know the answer to this but wanted confirmation anyway.
I ripped John Wick 4 and then, with DoVi_Scripts, plotted HDR10 and DV L1:
As you can see, DV has a higher MaxCLL by about ~400 nits. Is that why it's included here in this spreadsheet that shows DV grades that expand brightness?
Iam2smart
#8975 Post by Iam2smart » Wed Oct 04, 2023 3:39 pm
chronomac wrote: Wed Oct 04, 2023 3:30 pm I think I know the answer to this but wanted confirmation anyway.
Yes that's FEL so if it were to be convert to profile 8 which would not contain FEL it would be the incorrect brightness
thirdmoon
#8976 Post by thirdmoon » Thu Oct 05, 2023 5:11 am
@RESET_9999
Elemental 2023 4K BD
Image 1 - https://i.imgur.com/iuIWek1.png - Legacy Algo - Default Scaling
Image 2 - https://i.imgur.com/psmVkU8.png - Legacy Algo - 1080p custom scaling
Image 3 - https://i.imgur.com/OsCMDHZ.png - Most Highlight New Algo - Default Scaling
Image 4 - https://i.imgur.com/HL8crVV.png - Most Highlight New Algo - 1080p custom scaling
I'm confused which one to prefer. The new algo L1 seems to cut all highlights, in this case.
#8977 Post by RESET_9999 » Thu Oct 05, 2023 11:02 am
thirdmoon wrote: Thu Oct 05, 2023 5:11 am @RESET_9999
original WEB rpu is better, it has a manual L2 trim pass and the generated L1(new algo) looks pretty much like the original L1 (minus blended shots and cmv2.9)
https://slow.pics/c/8LNCceB0
skull88
#8978 Post by skull88 » Thu Oct 05, 2023 2:36 pm
RESET_9999 wrote: Thu Oct 05, 2023 11:02 am
Agreed. Retail DV is always preferable, if it has any manual trim pass and source PQ matches UHD BD.
thirdmoon
#8979 Post by thirdmoon » Fri Oct 06, 2023 3:20 am
Alright, thanks for the input. Incase of no manual trim pass or static DV, which one should be selected then?
skull88
#8980 Post by skull88 » Fri Oct 06, 2023 3:38 am
thirdmoon wrote: Fri Oct 06, 2023 3:20 am Alright, thanks for the input. Incase of no manual trim pass or static DV, which one should be selected then?
Latest Resolve, I do Most Highlight New Algo - 1080p custom scaling.
thirdmoon
#8981 Post by thirdmoon » Sun Oct 08, 2023 5:49 am
@RESET_9999
Is it possible to get heatmap and gamut from 7-3 in 2160p?
dapope
#8982 Post by dapope » Sun Oct 08, 2023 9:43 am
Does anyone know why I'm getting this error message when inputting a .TS file into 4-2? The MKV file works fine.
https://imgur.com/a/nNV7q4g
#8983 Post by RESET_9999 » Sun Oct 08, 2023 12:17 pm
thirdmoon wrote: Sun Oct 08, 2023 5:49 am @RESET_9999
you can try to edit line 11923 and 12059
echo final_image_resized = cv2.resize(final_image_rgb, (1955, 1080^), interpolation=cv2.INTER_AREA^) >> "%TEMP%heat_map.py"
and
echo final_image_resized = cv2.resize(cv2.cvtColor(original_img_cv, cv2.COLOR_RGB2BGR^), (1920, 1080^), interpolation=cv2.INTER_AREA^) >> "%TEMP%gamut_map.py"
#8984 Post by RESET_9999 » Sun Oct 08, 2023 12:17 pm
dapope wrote: Sun Oct 08, 2023 9:43 am Does anyone know why I'm getting this error message when inputting a .TS file into 4-2? The MKV file works fine.
Have you tried the latest version 1.9.5.5. There was a typo in that workflow for the TS/M2ts input in the previous versions.
thirdmoon
#8985 Post by thirdmoon » Sun Oct 08, 2023 5:45 pm
RESET_9999 wrote: Sun Oct 08, 2023 12:17 pm
and
Working thanks. Changed it in 6-7 as well.
