Re: Pioneer firmware update February 2023
#91 Post by MartyMcNuts » Tue Sep 12, 2023 10:49 am
mickstaa wrote: Tue Sep 12, 2023 10:40 am Hello all,
Noob here. can someone point me in the direction to patched UHD enabling firmware for my drive:
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-S12U
Revision: 1.00
Serial number: SGDL000006WL
Firmware date: 2019-01-10
Highest AACS version: 19
Drive platform: RS8F01
Firmware version: 1.00/ID43
What model is it? If it is a S12UHT then it already is UHD enabled.
alminderson
#92 Post by alminderson » Wed Sep 13, 2023 5:26 pm
I'd like to transition my LibreDrive status from Possible, not yet enabled to Enabled.
Running MakeMKV v1.17.4 on macOS Ventury 13.5.2:
Product: BD-RW BDR-XS07U
Revision: 1.03
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 655
Firmware version: ID05
My goal here, really, is just to remove the 2x speed limit for archiving my discs, and achieve the drive's 6x max speed as advertised. If LibreDrive isn't what I'm looking for to achieve that, I'd appreciate any advice or links.
#93 Post by Coopervid » Wed Sep 13, 2023 6:41 pm
Out of luck since your firmware is newer than Dec. 2012. Wait patiently for a fix by Mike.
#94 Post by Coopervid » Wed Sep 13, 2023 6:43 pm
Coopervid wrote: Wed Sep 13, 2023 6:41 pm Out of luck since your firmware is newer than Dec. 2012. Wait patiently for a fix by Mike.
You need to download the Pioneer Tool from their website to change options.
randomgeeza
#95 Post by randomgeeza » Wed Sep 13, 2023 6:59 pm
Is there a tool that works on macOS. I wouldn't mind a looks if there is...
#96 Post by MartyMcNuts » Wed Sep 13, 2023 9:45 pm
randomgeeza wrote: Wed Sep 13, 2023 6:59 pm Is there a tool that works on macOS. I wouldn't mind a looks if there is...
A tool for what?
#97 Post by Billycar11 » Wed Sep 13, 2023 9:49 pm
https://pioneer.jp/device_e/product-e/i ... iveUtility
InfinityX
#98 Post by InfinityX » Wed Sep 20, 2023 4:37 pm
We have a new official pioneer firmware 1.05. Do we have anything new with this new firmware?
BDR-S13U-X / S13E-X / S13C-X
ver. change point
1.05 Added a new function "Damage Prevention mode for music CD" Improved operational stability
https://pioneer.jp/cgi-bin/device/downl ... W105EU.exe
#99 Post by SamuriHL » Wed Sep 20, 2023 4:55 pm
More crap to prevent LibreDrive from working. Leave it alone.
TeddyRaspin
#100 Post by TeddyRaspin » Sat Sep 23, 2023 5:25 pm
1.05 fw version, as well as 1.04, upgrades also kernel part.
mrcontento
#101 Post by mrcontento » Sat Oct 07, 2023 7:12 pm
arremelle wrote: Mon Aug 14, 2023 1:36 pm Hi,
I have the same drive and situation as Asian wolf. I just got my drive from Amazon yesterday and I can read blu-rays just fine but not UHD.
MakeMKV is connected to the internet and I have been using it also for many years with DVD/Blu-rays no problem.
Replying so I can see any updates. Thanks in advanced for the support.
Same here .... waiting on solution for 1.03
palindromico
#102 Post by palindromico » Sun Oct 08, 2023 12:07 pm
Imagine that I had the player working and with the right FW, and (not knowing it, my fault) I updated it...
I'm calling myself an idiot every other day...
hydroptix
#103 Post by hydroptix » Sun Oct 08, 2023 3:04 pm
Would it be possible to put a warning into MakeMKV itself telling people not to upgrade firmware on Pioneer drives?
Probably currently watching Baby Driver on bluray, because all the streaming versions suck.
g0th1ckn1ght
#104 Post by g0th1ckn1ght » Fri Oct 13, 2023 3:20 am
I also stupidly upgraded my firmware on my BDR-XS07TUHD today to version 1.03 and I can no longer rip my UHD's. I went and bought a brand new one and it came with the dreaded 1.03 firmware, which I tried to return and got told to bad so sad the drive works.
Is this being worked on\can this be fixed or do I need to buy a different UHD drive?
ItsOdysseus
#105 Post by ItsOdysseus » Fri Oct 13, 2023 7:23 pm
Yep, i believe this is actively being worked on. Either an update to MKV for 1.03 or a way to safely downgrade software.
