Bullet Train UHD Error
GunerX
Post by GunerX »
I get about halfway through the file and it does this.
Hash check failed for file 00001.m2ts at offset 26183264256, file is corrupt.
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 26183147520, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 26183165952, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 26183190528, attempting to work around
Too many AV synchronization issues in file '/BDMV/STREAM/00001.m2ts' (title #-) , future messages will be printed only to log file
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '26187134976'
Error 'OS error - A device which does not exist was specified' occurred while reading '\Device\CdRom2' at offset '26187134976'
Failed to save title 0 to file F:/Make MKV - Temp folder for Ripping/Bullet Train_t00.mkv[;code]
Re: Bullet Train UHD Error
Give your disc a good clean before trying to rip again.
GunerX
Post by GunerX »
its a brand new disc. also I did clean it with a microfiber cloth.
Those errors mean the optical drive was unable to correctly read the disc in the location specified.
I've had plenty of brand new discs that have needed to be cleaned to be read properly.
Trying with a different optical drive can often yield a better result.
