A few months ago the 5.25 internal drive I had appeared to stop spinning and reading discs. After coming here and researching since I was going through neck issues at the time so I couldn't install a 5.25 drive I went with the HL-DT-ST BD-RE bp60nb10 LG external drive. At first things were really rough going with the drive saying that it wasn't present. I found that I needed to turn off the usb suspend option which I did and for a few months after that everything went really well ripping wise.
Recently way more discs I put in and get read by makemkv I am getting the drive isn't ready, and it keeps trying until the disc disappears in the OS. If I try to access the disc in power dvd I can access it no problem. I can't afford to go back to a 5.25 drive at this time. Any idea what is causing this? I have included my log. I downgraded to an older version of makemkv as well as I recently upgraded but that didn't help as well.
HL-DT-ST BD-REbp60nb10 drive having issues with reading blu ray and UHD disks
hlhbk
Re: HL-DT-ST BD-REbp60nb10 drive having issues with reading blu ray and UHD disks
Debug log started at Fri Oct 06 02:48:09 2023 , written by MakeMKV v1.17.2 win(x64-release)
001005:0000 MakeMKV v1.17.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\hlhbk/MakeMKV_log.txt
001003:0020 DEBUG: Code 1 at ;G$bZ015EvoWyW7RxE>11I{@:121261704
001003:0020 DEBUG: Code 3221225486 at ;G$bZ015EvoWyW7RxE>11I{@:121261727
001003:0020 DEBUG: Code 3221225486 at q_G<q2 y|*x`M.jt*.YU:213130582
005075:0000 The new version 1.17.5 is available for download at http://www.makemkv.com/download/
DEBUG: Code 3 at `6CF;l<+`$x9]D6No(y!wmrg:29395310
SDF v098: HL-DT-ST_BD-RE_BP60NB10_1.02_212005070935_SIM03L93H5954
DEBUG: Code 4279603457 at FP)57'8krEc6"9E\K:29396736
DEBUG: Code 0 at FP)57'8krEc6"9E\K:213133089
DEBUG: Code 4278268161 at FP)57'8krEc6"9E\K:29396736
DEBUG: Code 1 at FP)57'8krEc6"9E\K:213133089
DEBUG: Code 2 at FP)57'8krEc6"9E\K:213133089
DEBUG: Code 3 at FP)57'8krEc6"9E\K:213133089
DEBUG: Code 4 at FP)57'8krEc6"9E\K:213133089
DEBUG: Code 5 at FP)57'8krEc6"9E\K:213133089
DEBUG: Code 4278268161 at FP)57'8krEc6"9E\K:29397104
DEBUG: Code 0 at 5iB7,;15sKs-6#4;:121269777
001003:0020 DEBUG: Code 3221225664 at ze@?D]{aalB&'!=Y:213130559
001003:0020 DEBUG: Code 3221225664 at 7\p$41hKadpJ}AJisc:121263429
001003:0020 DEBUG: Code 3221225664 at 7\p$41hKadpJ}AJisc:121262302
002003:0000 Error 'OS error - This device does not exist' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM03L93H5954' at offset '524288'
002003:0000 Error 'OS error - This device does not exist' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM03L93H5954' at offset '1048576'
002003:0000 Error 'OS error - This device does not exist' occurred while reading 'BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM03L93H5954' at offset '32768'
001003:0020 DEBUG: Code 0 at +&8OS6}j6SLdiJW=|}*:213129777
