Trouble Ripping UHD
KetchupGore
Trouble Ripping UHD
#1 Post by KetchupGore » Mon Oct 02, 2023 3:18 pm
Hey there!
Not sure if this is the right category, but I'm currently experiencing an error when trying to rip UHDs. Some information on what I'm working with..
OS: macOS Sonoma 14.0 (recent)
MakeMKV: v1.17.5 (recent)
Drive: BDR-UD04 (LibreDrive enabled)
I'm using this software and drive for years now and didn't had any problems what so ever, but as of today I am apparently unable to rip UHDs. I first noticed it with the Arrow Video release of Mary Shelleys Frankenstein. Then I tried some titles I knew would work cause I ripped them before, to make sure it's not just a bad disc. Still errors after errors..
Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
Does anybody know a solution or has a similar issue?
And I want to add its definitely not because of dirty or faulty discs. Some are brand new and others have only been played once and remain carefully stored since.
EDIT: After cleaning all discs and the lens I was still getting the same error. Only for UHDs I want to add. All Blu Rays I tested loaded up fine. So I just started throwing all UHDs I have at MakeMKV to see if I could get even one of them to read and I got lucky. Lord of War did open and and I noticed a line in the log reading:
Downloading latest HK to /Users/directory..
Not sure if it has something to with it but eversince MakeMKV is fully functioning again.
Re: Trouble Ripping UHD
#2 Post by Woodstock » Mon Oct 02, 2023 4:25 pm
The drive is disagreeing that the disks are perfectly readable. Have you tried resetting the drive (power off)? Cleaning the disks?
EventDriven
#3 Post by EventDriven » Wed Oct 04, 2023 3:37 pm
Sounds like your drive doesn't like it which is something that occasionally happens. Not that this helps you right now, but if you have a large number of discs to go through then you may find it helpful having more than one drive if possible. I've got two different drives, an Asus and a Buffalo, and have found that if one doesn't work then sometimes the other will.
