The volume key is unknown for this disc
Highlander1701
Post by Highlander1701 » Sat Sep 30, 2023 1:39 am
Hi! This is the first time since i started using MakeMKV I ever had an error of any kind so I thought I would put it to the forum to see if anyone could help. I'm running the latest registered version of MakeMKV if that makes any difference. The error I get is as follows:
The volume key is unknown for this disc - video can't be decrypted.
It might be the disk is newly released within the past fortnight.
Thanks for any help or comments
Regards
H!
I have included drive/disk details for info below:
OS device name: Y:
Manufacturer: PIONEER
Product: BD-RW BDR-S12U
Revision: 1.03
Serial number: *************
Firmware date: 2022-10-13
Highest AACS version: 70
Drive platform: RS8F01
Firmware version: 1.03/ID43
Disc Information
Label: THE_WICKER_MAN_DISC1
Timestamp: 2023-08-14 11:22:15
Protection: AACS2.0/C v70
Data capacity: 90.82 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
MakeMKV v1.17.5 win(x64-release) started
Using LibreDrive mode (v01.0 id=13C675B104B8)
Saved AACS dump file as C:\Users\[redacted]/.MakeMKV/MKB20_v70_The_Wicker_Man_-_Disc_1_3559.tgz
Re: The volume key is unknown for this disc
Post by Woodstock » Sat Sep 30, 2023 2:38 am
And you've forwarded this file to svq@makemkv.com for processing, yes?
Radiocomms237
Post by Radiocomms237 » Sat Sep 30, 2023 9:46 am
Highlander1701
Post by Highlander1701 » Mon Oct 02, 2023 1:53 pm
Possibly the same title:
https://forum.makemkv.com/forum/viewtopic.php?f=12&t=31917
Yes I it is the same title!
Regards
Highlander1701
Post by Highlander1701 » Mon Oct 02, 2023 1:55 pm
I have now on your suggestion.
wyattzirb
Post by wyattzirb » Wed Oct 25, 2023 1:00 am
How quick did this get solved? or did it at all?
I have two 4K Blurays without volume keys and one just released two days ago.
Post by Woodstock » Wed Oct 25, 2023 1:59 am
Most keys are generated within a couple of days after the "important bits" (i.e., the .TGZ file generated) are submitted to the author.
You do, of course, have to submit them AND allow MakeMKV access to the outside world so it can fetch them.
captainbdsc
Post by captainbdsc » Tue Mar 05, 2024 3:48 am
How can I tell if MakeMKV is actually downloading the latest keys, or however that works. Or do I suppose it is able to reach the service if there is no error about not getting to it.
I am still trying to rip Wonka (2023) 4K.
Post by dcoke22 » Tue Mar 05, 2024 5:34 pm
MakeMKV shows a message in the log when it downloads new hashed keys. It looks like:
Downloading latest HK to C:\Users\xxxxxxxxx/.MakeMKV ...
If it tries to download hashed keys and it fails, there'll be a message for that too.
captainbdsc
Post by captainbdsc » Tue Mar 05, 2024 7:40 pm
Thank you for the response!
I am not seeing either one of these things in the log... what does that mean?
Here is my Info and Log:
Product: BD-RE WH16NS60
Revision: 1.03
Serial number: KLZKBPA4529
Firmware date: 2120-05-08 10:10
Highest AACS version: 77
Disc Information
Label: WONKA
Timestamp: 2024-01-03 09:21:59
Protection: AACS2.0/C v77
Data capacity: 81.21 Gb
Number of layers: 3
Using LibreDrive mode (v06.3 id=4083C4CCDB14)
Saved AACS dump file as C:\Users\[USERNAME]/.MakeMKV/MKB20_v77_Wonka_449A.tgz
DEBUG: Code 0 at g1G,9/u[_c:!rg}]:213132721
DEBUG: Code 0 at g1G,9/u[_c:!rg}]:213131341
EDIT: removed giant smiley and changed my last comment into a question, and added drive/disc info and log
MyJunkIsBroken
Post by MyJunkIsBroken » Thu Mar 07, 2024 3:57 pm
I too am not seeing anything in the logs regarding trying to download new keys. I'm still not able to rip two 4k discs I own.
I made submissions twice for both 4k versions of The Martian Extended ( MKB20_v60_The_Martian_-_Extended_Edition_F8C9.tgz ), and Bohemian Rhapsody ( MKB20_v66_Bohemian_Rhapsody_65F1.tgz ). The original submission I made over 2 years ago, and the re-submission a few weeks ago.
Post by dcoke22 » Fri Mar 08, 2024 6:20 am
Your log suggests that your MakeMKV thinks it has the latest set of hashed keys and that the key needed for Wonka (2023) is not yet available. The thread Wonka 4k Dump Submitted indicates that someone sent that same dump, MKB20_v77_Wonka_449A.tgz, on February 24, 2024. I don't see anyone saying they have gotten a hashed key for it in the usual MakeMKV way. Some people have reported success using the keydb.cfg method, which you can find links for in the Wonka thread.
Post by dcoke22 » Fri Mar 08, 2024 6:25 am
Maybe post a full log? I would expect those older titles to have hashed keys available.
MyJunkIsBroken
Post by MyJunkIsBroken » Fri Mar 08, 2024 5:30 pm
OS device name: F:
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM03NBA92907
Firmware date: 2120-05-07 09:35
Highest AACS version: 66
Firmware version: 1.02
Disc Information
Label: THE MARTIAN EXTENDED EDITION
Timestamp: 2016-04-26 14:55:30
Protection: AACS2.0/C v60
Data capacity: 60.49 Gb
Number of layers: 2
MakeMKV v1.17.6 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\owner/MakeMKV_log.txt
DEBUG: Code 0 at WKYQi`r2nRn]/W8S:213144750
Using LibreDrive mode (v06.3 id=4C194CE2C4D1)
Saved AACS dump file as D:/Video/MKB20_v60_The_Martian_-_Extended_Edition_F8C9.tgz
Disc Information
Label: BOHEMIAN_RHAPSODY
Timestamp: 2018-12-11 14:22:18
Protection: AACS2.0/C v66
Data capacity: 61.13 Gb
Number of layers: 2
Saved AACS dump file as D:/Video/MKB20_v66_Bohemian_Rhapsody_65F1.tgz
captainbdsc
Post by captainbdsc » Fri Mar 08, 2024 7:52 pm
I was successful today at ripping Wonka (2023) 4K
It did show "Downloading latest HK..." this time
Here is the log:
Debug logging enabled, log will be saved as C:\Users\[USERNAME]/MakeMKV_log.txt
Downloading latest HK to C:\Users\[USERNAME]/.MakeMKV ...
