1. Measuring only the BL
For movies that have a MDL mismatch like The Avengers would you recommend editing L6 or just leaving it alone. Thanks
it doesnt really matter, both are ok
Ill just leave it be then Thanks for the Reply
onlysleeping23
So I’ve been ripping discs in my collection, adding audio tracks, then remuxing back to usb flash drives in bdmv format for chapter support, only retaining the main feature for playback on my x800m2.
Following directions for option 2 of the x800m2 in the dolby vision stuff sheet, and using tsmuxer nightly in order to keep dolby vision, I notice if I remux the playlist file to bdmv, mediainfo shows two streams, neither listing dv.
If I remux the m2ts file, I now see dv in mediainfo, as expected.
If I then remux the new m2ts back to bdmv, mediainfo no longer shows dolby vision.
Am I doing something wrong? Should I only remux to m2ts to keep dolby vision, and manually place it in the bdmv structure?
Would really appreciate any advice/help!
@onlysleeping23 it's normal and look at an original DV BD folder , you'll see that it's the same.
I think I know the answer to this but wanted confirmation anyway.
I ripped John Wick 4 and then, with DoVi_Scripts, plotted HDR10 and DV L1:
As you can see, DV has a higher MaxCLL by about ~400 nits. Is that why it's included here in this spreadsheet that shows DV grades that expand brightness?
Yes that's FEL so if it were to be convert to profile 8 which would not contain FEL it would be the incorrect brightnesschronomac wrote: ↑Wed Oct 04, 2023 3:30 pmI think I know the answer to this but wanted confirmation anyway.
@RESET_9999
Elemental 2023 4K BD
Image 1 - https://i.imgur.com/iuIWek1.png - Legacy Algo - Default Scaling
Image 2 - https://i.imgur.com/psmVkU8.png - Legacy Algo - 1080p custom scaling
Image 3 - https://i.imgur.com/OsCMDHZ.png - Most Highlight New Algo - Default Scaling
Image 4 - https://i.imgur.com/HL8crVV.png - Most Highlight New Algo - 1080p custom scaling
I'm confused which one to prefer. The new algo L1 seems to cut all highlights, in this case.
original WEB rpu is better, it has a manual L2 trim pass and the generated L1(new algo) looks pretty much like the original L1 (minus blended shots and cmv2.9)thirdmoon wrote: ↑Thu Oct 05, 2023 5:11 am@RESET_9999
https://slow.pics/c/8LNCceB0
Agreed. Retail DV is always preferable, if it has any manual trim pass and source PQ matches UHD BD.RESET_9999 wrote: ↑Thu Oct 05, 2023 11:02 amoriginal WEB rpu is better, it has a manual L2 trim pass and the generated L1(new algo) looks pretty much like the original L1 (minus blended shots and cmv2.9)thirdmoon wrote: ↑Thu Oct 05, 2023 5:11 am@RESET_9999
Alright, thanks for the input. Incase of no manual trim pass or static DV, which one should be selected then?
@RESET_9999
Is it possible to get heatmap and gamut from 7-3 in 2160p?
Does anyone know why I'm getting this error message when inputting a .TS file into 4-2? The MKV file works fine.
https://imgur.com/a/nNV7q4g
