Cells automatically deleted from MKV file.
Rysiek180
Post by Rysiek180 »
I have a problem with ripping one particular DVD with very important stuff for me. MakeMKV automatically deletes cells from the output video, which results in 10 minutes of the video missing. How do I force the program to keep all of the DVD content?
LOG:
Debug log started at Sun Oct 01 17:29:12 2023 , written by MakeMKV v1.17.5 win(x64-release)
001005:0000 MakeMKV v1.17.5 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\xxx/MakeMKV_log.txt
DEBUG: Code 3 at p#THBi/ll*BA2gQ6"dN^+C5W:29395310
SDF v098: ASUS_BW-16D1HT_3.10_211901041014_KLEL8IB0734
DEBUG: Code 2317353435 at oKy{<P[rsI9$ xH93:121265246
DEBUG: Code 0 at oKy{<P[rsI9$ xH93:213133388
DEBUG: Code 1 at oKy{<P[rsI9$ xH93:213133388
DEBUG: Code 2 at oKy{<P[rsI9$ xH93:213133388
DEBUG: Code 3 at oKy{<P[rsI9$ xH93:213133388
DEBUG: Code 4 at oKy{<P[rsI9$ xH93:213133388
DEBUG: Code 5 at oKy{<P[rsI9$ xH93:213133388
DEBUG: Code 2317353435 at oKy{<P[rsI9$ xH93:29396943
DEBUG: Code 0 at 6XX(~WMlif ;_K(I:29401750
DEBUG: Code 1 at ,D"[N&a~mz_cLb08a:121263199
Launching D:\Programy\MakeMKV\mmgplsrv64.exe
DEBUG: Code 0 at !\uy]#z`q,hoIpd~itA.:29396460
003037:0000 Cells 1-37 were removed from title start
003038:0000 Cells 192-192 were removed from title end
003028:0000 Title #1 was added (154 cell(s), 0:40:48)
Application exited at Sun Oct 01 17:29:38 2023
Chetwood
Re: Cells automatically deleted from MKV file.
Post by Chetwood »
How about ripping the DVD with DVD Shrink to ISO and only then making an mkv out of it? Maybe the results will differ.
Rysiek180
Post by Rysiek180 »
Chetwood wrote:
Thu Oct 05, 2023 6:37 am
Hi, @Chetwood
I made the ISO with DVD Shrink but results are the same.
I was wondering if somehow I could force these cells to be present on the final video via PRO mode, but there is very little about its syntax and I have no idea how to take care of it.
Thanks,
Rysiek18
Chetwood
Post by Chetwood »
Sorry, neither do I.
What happens if you use MakeMKV to make a decrypted backup of the disc? Recent versions of MakeMKV have started supporting that for DVDs. I think you'll end up with a .iso file.
Post by d00zah »
Rysiek180 wrote:
Sun Oct 01, 2023 6:39 pm
2 thoughts...
Rather than 'auto', try manually setting different DVD opening modes - CellWalk, CellTrim, CellFull
Try Manual DVD mode
