RESET_9999 wrote: Sat Sep 30, 2023 7:17 pm
No idea compared to your oppo but I prefer the PQ of the ATV better than the Shield.
Sorry I wasn’t clear. Knowing that the ATV has some clipping (Y low, Cr Low), does that translate in some perceivable difference for Picture Quality(PQ)?
I recall that Y(Luma) tends to be more important than Cr/Cb , I wonder if we’d expect crushed blacks or whatever ...
Doing back to back comparison with Oppo is difficult bcoz it takes like 5s on my TV to switch from DV to whatever then to DV. so I found it hard to do that comparison.
I copied inline the S&M explanation for that area of the pattern:
Clipping
Y high / low and Cr high / low
These boxes test whether the Y’CbCr channels are getting clipped at the reference high / low levels before being converted to RGB. This is always wrong; clipping should always be done as late as possible in the display pipeline, and certainly only in RGB.
If Y’CbCr is being kept intact until RGB conversion, there should be clearly visible lighter or darker small squares in the center of each of the four larger squares. If one or more of the channels in Y’CbCr is being clipped, one or more of the smaller squares will not be visible.
