^^^ Thanks, it is known that P7 MEL conversion to P8 is “lossless”. What I think was being pondered on, whether PQ for viewing a P8 movie is the same in a video processing chain using a reference video player vs the aforementioned software streamers (Infuse, Plex) on an ATV 4K.
Using the above test pattern, ATV DV processing of that P8 test pattern yielded different results than using the same pattern on an Oppo UDO-203 w same cables/TV. Reading S&M explanation of that test pattern kinda implies something funky happening with ATV DV processing for that P8 pattern.
Seeing difference between FEL and MEL/Profile 8/recodes and really enjoying it are two different things indeed.
To be able to assess, first off you must be able to see FEL in its full glory, which I think very few of us can do. It takes a native 12 bit screen in the first place and its ability to display full blown 12 bit luminance. To my knowledge there are none for consumers (yet?), unless things have changed. So be aware that you're probably watching down-to-10 bit FEL DV on your screen. Nevertheless, even then FEL can look better. Also, FEL advantage takes players which Dolby Vision Composer actually process FEL. Such as DV compliant UHDBD players and some mediaplayers.
I won't go into personal taste. I do think a lot of recoding is done to save up on harddrive space. For those who do experience FEL as the walhalla, won't do any of it, my guess.
aboulfad wrote: ↑Sat Sep 30, 2023 3:53 pm^^^ Thanks, it is known that P7 MEL conversion to P8 is “lossless”. What I think was being pondered on, whether PQ for viewing a P8 movie is the same in a video processing chain using a reference video player vs the aforementioned software streamers (Infuse, Plex) on an ATV 4K.
that P8 pattern file looks correct only on cmv2.9 devices.
It has issues on all the cmv4.0 devices.
ATV:
strange artifacts in the red and blue ramps
issues in the Y’CbCr clipping
Shield:
banding in the blue ramps (I think its the reason for the red push)
issues in the colorspace conversion (goes away in LLDV)
FireTV:
st2084 tracking different that all the other device.
looks darker
C2 internal player:
thank you for the summary from previous experiment: viewtopic.php?p=134248#p134248 , I think ATV can only process P8 w cmv2.9, does it mean it’s a cmv2.9 device ? so I am a bit confused by the above two statements.RESET_9999 wrote: ↑Sat Sep 30, 2023 4:07 pm…
it doesn't matter it still uses the most recent CMV4.0 engine to playback DV regardless of the input version and the pattern is cmv2.9 anyway.aboulfad wrote: ↑Sat Sep 30, 2023 4:18 pmthank you for the summary from previous experiment: viewtopic.php?p=134248#p134248 , I think ATV can only process P8 w cmv2.9, does it mean it’s a cmv2.9 device ? so I am a bit confused by the above two statements.
Hmm, so if we had a cmv4.0 DV test pattern, would we expect better conformance to that test pattern on ATV?RESET_9999 wrote: ↑Sat Sep 30, 2023 4:21 pmit doesn't matter it still uses the most recent CMV4.0 engine to playback DV regardless of the input version and the pattern is cmv2.9 anyway.
No, I tried a 4.0 version of this pattern and it's the same issues. (At least on the C2 and Shield)
But I think I read about Stacey Spears saying that Dolby ordered a bunch of their new benchmark discs so maybe that will be improved in the future.
That’d be funny, Dolby Labs using S&M test patterns. I wouldn’t hold my breath between Dolby & Apple to have something changed anytime soon.RESET_9999 wrote: ↑Sat Sep 30, 2023 4:37 pm…
If you take a guess, what do you think would be impacted when viewing a movie based on the difference(s) of ATV’s processing of that one pattern?
no
cm analyze requires a prores file.
No idea compared to your oppo but I prefer the PQ of the ATV better than the Shield.
Sorry I wasn’t clear. Knowing that the ATV has some clipping (Y low, Cr Low), does that translate in some perceivable difference for Picture Quality(PQ)?RESET_9999 wrote: ↑Sat Sep 30, 2023 7:17 pmNo idea compared to your oppo but I prefer the PQ of the ATV better than the Shield.
I recall that Y(Luma) tends to be more important than Cr/Cb , I wonder if we’d expect crushed blacks or whatever ...
Doing back to back comparison with Oppo is difficult bcoz it takes like 5s on my TV to switch from DV to whatever then to DV. so I found it hard to do that comparison.
I copied inline the S&M explanation for that area of the pattern:
Clipping
Y high / low and Cr high / low
These boxes test whether the Y’CbCr channels are getting clipped at the reference high / low levels before being converted to RGB. This is always wrong; clipping should always be done as late as possible in the display pipeline, and certainly only in RGB.
If Y’CbCr is being kept intact until RGB conversion, there should be clearly visible lighter or darker small squares in the center of each of the four larger squares. If one or more of the channels in Y’CbCr is being clipped, one or more of the smaller squares will not be visible.
I still dont know how this reflects in real content but the problem seems to be more than just clipped channels because IIRC, the whole square turns black instead of green/red as on cmv2.9 devices or in the SM docs.
If that was just a clipping problem you just wouldn't be able to see the lighter/small red/green square.
^^^ thanks for your replies, indeed the Ylow & CrLow squares are black. I just thought maybe I can send the ATV screenshot to S&M and ask. Buying their new UHD disc would be the official way to get some of their support : )
@Stacey usually responds to users questions here: https://forum.blu-ray.com/showthread.ph ... 27&page=41
Awesome, thank you ! I’ll read the 50 or so pages & post there. Tons of info, I’ve found two posts by Stacey that may be relevant to that test pattern, ATV & clipping (unsure if it’s about SDR only)RESET_9999 wrote: ↑Sat Sep 30, 2023 10:19 pm@Stacey usually responds to users questions here: https://forum.blu-ray.com/showthread.ph ... 27&page=41
1. https://forum.blu-ray.com/showpost.php? ... tcount=878
2. https://forum.blu-ray.com/showpost.php? ... count=1224
