1.17.5 errors
bswogger
1.17.5 errors
#1 Post by bswogger » Thu Sep 28, 2023 8:27 pm
i just installed 1.17.5 and tried to process avatar way of water 4k ultra HD, it will not work, it gets scsi errors and fails.
it worked fine on 1.17.4.
i tried uninstalling and deleting registry keys, then installing again, but still fails
Other HD discs work,
and this disc did work before installing 1.17.5, now even when i re insatall 1.17.4 it still wont work.
yes i removed .5 version
log
FFMIX001: [FFM_AudioMix @ 00000072EAFFBE00]   0.212   0.212   0.425   (SKIP)  0.038   0.038   0.038   0.038
001003:0020 DEBUG: Code 3221225488 at e0)""ua'FL?Ifeb9:213130559
002003:0000 Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '3070973952'
001003:0020 DEBUG: Code 101000192 at 6XX(~WMlif ;_K(I:121271617
001003:0020 DEBUG: Code 101000192 at e0)""ua'FL?Ifeb9:213130559
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00102.m2ts' at offset '3070973952'
DEBUG: Code 101000192 at T*66mI"9R%2H!-6CI':29394896
001003:0020 DEBUG: Code 101000192 at T*66mI"9R%2H!-6CI':213131502
001003:0020 DEBUG: Code 0 at %K{3+D<I-p.W2g)K$P73:29395471
001003:0020 DEBUG: Code 0 at >u+x)D9+i6!-r0Fh7!4O:29394068
001003:0020 DEBUG: Code 0 at %K{3+D<I-p.W2g)K$P73:213131157
001003:0020 DEBUG: Code 0 at %K{3+D<I-p.W2g)K$P73:121262647
001003:0020 DEBUG: Code 1499499 at %K{3+D<I-p.W2g)K$P73:121261773
001003:0020 DEBUG: Code 0 at 5#w%HEc@g}P<=`%X^J>Av:213137068
001003:0020 DEBUG: Code 0 at #U-CH*_@vi7X5z=Cjizv:29394022
001003:0020 DEBUG: Code 0 at #U-CH*_@vi7X5z=Cjizv:29404878
001003:0020 DEBUG: Code 0 at #U-CH*_@vi7X5z=Cjizv:29405384
001003:0020 DEBUG: Code 0 at #U-CH*_@vi7X5z=Cjizv:29403383
001003:0020 DEBUG: Code 0 at rW7LRhJZY*VT:"D7:213132537
001003:0020 DEBUG: Code 0 at qy}7fzg[F3@N8=&KW:121264464
001003:0020 DEBUG: Code 0 at qy}7fzg[F3@N8=&KW:121263912
001003:0020 DEBUG: Code 0 at qy}7fzg[F3@N8=&KW:213130145
001003:0020 DEBUG: Code 3221225488 at p#THBi/ll*BA2gQ6"dN^+C5W:121262371
DEBUG: Code 3221225488 at T*66mI"9R%2H!-6CI':29394896
001003:0020 DEBUG: Code 3221225488 at T*66mI"9R%2H!-6CI':213131502
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
---- Failed F:/ripping video/bluray-dvd files/Avatar- The Way of Water_t00.mkv
ch_0        4494905415000 0
ch_1        4495716225000 0
ch_2        4496797305000 0
ch_3        4497878385000 0
ch_4        4499049555000 0
ch_5        4500130635000 0
ch_6        4501211715000 0
ch_7        4502427930000 0
mt=000001A1EFF9B920 n=20
s=0 n=1 o=3070973952
s=6 n=0 o=3070973952
s=7 n=0 o=3070973952
s=8 n=0 o=3070973952
s=9 n=0 o=3070973952
s=10 n=0 o=3070973952
s=11 n=0 o=3070973952
s=12 n=0 o=3070973952
s=13 n=0 o=3070973952
s=14 n=0 o=3070973952
s=15 n=0 o=3070973952
s=16 n=0 o=3070973952
s=17 n=0 o=3070973952
s=18 n=0 o=3070973952
s=19 n=0 o=3070973952
mt=000001A1ED385610 n=20
    0  56336 000008  4502608110000       45045000 B9C1E78A 00000003460150000000104E010103040814880670C08F430410800000DBF10201E21ADB80F08BB8403000071800112A001116000B34000AFE001FFA0023780021BA000CDE002492002BB600398C000F80002DCC001D55E290B0944F2C5B2FCDED35D766ACADC48CB95F8D15D8B0A8785A5F3E465B8C51195BA64A944D77EB79
s=1 n=1 o=3066544128
    1    552 000000  4502460801000         900000 E996ADF9 11146D307026605060D0610E0828F570FF9195039DF2BE7DB52EDF5C0540C1C1F436C56BB164854AFFB9F796AA885C0FACD8BCFDA2C2252A981A983E6B42CF85A62608F279CB56430EB3F0938C8EB7FAE19DF5E8734026D279D6842952606BD436C55252080B2728B8CB0F48A3FB6629D4A4E78B96B4534F421116D7DD918D99
s=2 n=1 o=3066974208
    2   2560 002001  4502538945000       34560000 F2E968CA 0B779E462430E3DC04F4B2D00003F02969E186186169553E7BAE1A5A946B3E86A9F3EA549F2653614A67EB69BB49110BE7CED3257D577BE7D5AC2A735DF26A50A9577B4DD2A54A9F3A74FD128D74763A530A9BE7BE207B5ADA486FAB52ACE9F435B0B5A672FA94442F9F534AFDF52D6FD2C25546BBDB6A92D84D09FBCAF0D2D2
s=3 n=1 o=3070672896
    3   4096 002001  4503575745000       34560000 E813F15D 0B77C4A12230E3DFFCF4B2D00003E955E186186181E3C37D0D32673514BE74D9F527CFDED3535DF2AAB4D5567EA5F3F54BD4BA7D0064F6B0D32DAD6DF2674EA13EA6EA0C3535D5A4AF09F3E855E8C35C9953E4DC1423D73577CF2BC37EE1F44735A9C27B112C37B5A942A559FD87336124DA360BF7CF9F43875DC53B50A0EBDF
s=4 n=1 o=3070672896
    4   4096 002001  4503575745000       34560000 CF85909F 0B77476A2230E3DFFCF4B2D00003E975E1861861821757A54D3257D514D274D9F52CCFDED354F9F2AD34DF5A7E56B3F7D0D43FA4FD33A74A92C6856ABCE7E85FA5A55E0C3535D529AF09F3E855E8D68E99F3E4BB898921F3A496EDBD550D4D68F49ED354E92D74CA6B55B74A1577CFD52654F9D4D7EF9F41A759FC27CEA73E84
s=5 n=1 o=3070672896
    5   2304 002001  4503610305000       34560000 4049B377 0B77CD9F2230E3DFFCF4B2D00003EA65E18618618229C28F09F3E7EF9D3E7CF9F5B7B115297EF69A57EF9FA6A4F623A4B5A9BF1BB0D8972B3F71C28DBA5510B4AF4D2D2A6986BECCF9FA57E969BA9CE5FB9AEE9CC44AA9D3990E75577CF6C257E99D3A4CFA14F4CE9EC37D09F46AE99FA9AEA935832C2A550DF3E86A333E7D64
005003:0000 Failed to save title 0 to file F:/ripping video/bluray-dvd files/Avatar- The Way of Water_t00.mkv
Encountered 149 unclassified errors
error=0x06052400 count=83 name=Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB
error=0xC0000010 count=66 name=OS error - The specified request is not a valid operation for the target device
005004:0080 0 titles saved, 1 failed
Application exited at Fri Sep 29 20:47:47 2023
Re: 1.17.5 errors
#2 Post by dcoke22 » Fri Sep 29, 2023 2:53 pm
It would be helpful if you posted the log of the failed attempt.
In the meantime, if it works for you on 1.17.4 the old versions of MakeMKV can be found here: https://www.makemkv.com/download/old/ A paid-for license might be required to use old versions of MakeMKV, although I don't know for sure.
bswogger
Re: 1.17.5 errors
#3 Post by bswogger » Fri Sep 29, 2023 8:54 pm
log added to OP
Bagdad48
Re: 1.17.5 errors
#4 Post by Bagdad48 » Mon Jun 17, 2024 5:38 pm
Having the same issue here as well. Any idea how to address or correct this?
Saving 1 titles into directory K:/4K Movies 2023/Avatar- The Way of Water
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00120.m2ts' at offset '1946511360'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '1946511360'
Failed to save title 0 to file K:/4K Movies 2023/Avatar- The Way of Water/Avatar- The Way of Water_t00.mkv
Re: 1.17.5 errors
#5 Post by mike admin » Mon Jun 17, 2024 8:48 pm
This should have nothing to do with version, looks like a generic SCSI error.
