The Goonies - errors...
hahafunny
Post by hahafunny »
Error 'Scsi error - MEDIUM ERROR:DATA SYNCHRONIZATION MARK ERROR' occurred while reading '/BDMV/STREAM/00113.m2ts' at offset '14223409152'
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00113.m2ts' at offset '14226487296'
DEBUG: Code 0 at _y.Wha8OK(K)>ze|cZy3:29394298
DEBUG: Code 0 at [9oc2-g2Vj~;@2}X@%m_:121261681
DEBUG: Code 0 at _y.Wha8OK(K)>ze|cZy3:29394183
DEBUG: Code 6946527 at _y.Wha8OK(K)>ze|cZy3:29393309
Failed to save title 1 to file /Volumes/GoFlex Home Public/blu ray rips/The Goonies/title01.mkv
0 titles saved, 1 failed
and from the log file:
Debug log started at Thu Jun 23 13:42:33 2011 , written by MakeMKV v1.6.10 darwin(x86-release)
001005:0000 MakeMKV v1.6.10 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/MakeMKV_log.txt
002014:0000 Optical drive "BD-RE MATSHITA BD-MLT UJ230AS 1.11" opened in DASPI v1.3 mode.
005050:0000 Evaluation version, 18 day(s) out of 30 remaining
DAFD=PAAAADAAAAEABDQUEAQEBAQIBDQAAAAAgAAAAAAAAAAA=
DCE=9/IGtei//NePm0kk7w/enK3Kerrb1BWUUbab0FWg1rFr7oV0DMbIHDN0TgIMgVwbsDpwNN/igEGUhT0I+yaCopKgka7m7kXZBwvOOUxuu4s8vlceUWZkiUT7z7rpwTif3AJVc8ngHW7UInk/p/2gNwcbCWbXaFVKCA==
DISCID=9BCCE8A7888B58E9FB8D8E054C2BCBC9EC61006A
003307:0000 File 00030.mpls was added as title #0
003307:0000 File 00031.mpls was added as title #1
003309:0000 Title 00000.mpls is equal to title 00031.mpls and was skipped
003307:0000 File 00008.mpls was added as title #2
003307:0000 File 00016.mpls was added as title #3
003025:0000 Title #00024.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003309:0000 Title 00026.mpls is equal to title 00031.mpls and was skipped
003307:0000 File 00027.mpls was added as title #4
003025:0000 Title #00028.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00013.m2ts was added as title #5
003307:0000 File 00014.m2ts was added as title #6
003307:0000 File 00027.m2ts was added as title #7
003307:0000 File 00028.m2ts was added as title #8
003025:0000 Title #00037.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00109.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00110.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00111.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Volumes/GoFlex Home Public/blu ray rips/The Goonies
001003:0020 DEBUG: Code 1073741829 at )Cb.?d~[?2i`@"#*:29393953
001003:0020 DEBUG: Code 2 at -N#YL4P(3f)A0CMS:121268719
002003:0000 Error 'Scsi error - MEDIUM ERROR:DATA SYNCHRONIZATION MARK ERROR' occurred while reading '/BDMV/STREAM/00113.m2ts' at offset '14223409152'
002003:0000 Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00113.m2ts' at offset '14226487296'
001003:0020 DEBUG: Code 0 at _y.Wha8OK(K)>ze|cZy3:29394298
001003:0020 DEBUG: Code 0 at [9oc2-g2Vj~;@2}X@%m_:121261681
001003:0020 DEBUG: Code 0 at _y.Wha8OK(K)>ze|cZy3:29394183
001003:0020 DEBUG: Code 6946527 at _y.Wha8OK(K)>ze|cZy3:29393309
005003:0000 Failed to save title 1 to file /Volumes/GoFlex Home Public/blu ray rips/The Goonies/title01.mkv
005004:0080 0 titles saved, 1 failed
AppleTV 2
Re: The Goonies - errors...
Post by mike admin »
hahafunny wrote:Error 'Scsi error - MEDIUM ERROR:DATA SYNCHRONIZATION MARK ERROR' occurred while reading '/BDMV/STREAM/00113.m2ts' at offset '14223409152'
You should really get a new drive. These are physical disc errors.
hahafunny
Post by hahafunny »
A new drive? Would a better drive handle the discs better or did you mean that the disc is defective and that i need a new disc?
thanks!
AppleTV 2
setarip_old
Post by setarip_old »
Hi!
I believe that the first of the 3 quoted errors is, by itself, indicative of a disc (media) problem. However, the second and third errors clearly indicate problems with the physical drive - and, as such, may cause the first type of error as well...
hahafunny
Post by hahafunny »
hi guys, i got a replacement disc from the shop and successfully ripped The Goonies just now... whew!
i've never had any problems with regular dvd but having just got a blu ray drive for my computer because i was so dissapointed with the video quality from the iTunes store HD movies that I bought... basically really surprised that i've had so many bad discs in such a short time... maybe a better drive can deal with disc defects more easily???
anyway, much happier with even the 720p that i get after handbraking to AppleTV 2 settings after using makemkv....
it isn't as quick as downloading from itunes but at least i don't have to suffer the dismal itunes hd quality.... whew!
AppleTV 2
