Does anyone know what streaming services provide the best quality Dolby Vision? I've been told different streaming services offer different quality Dolby Vision metadata. Do we have a list of streaming services what provide what features?
The L1/L2 metadata is most of the time exactly the same on all the streaming services. Only iTunes is slightly different with the static color reshaping, missing Level 4 and 5Trees wrote: Thu Sep 28, 2023 10:00 am Does anyone know what streaming services provide the best quality Dolby Vision? I've been told different streaming services offer different quality Dolby Vision metadata. Do we have a list of streaming services what provide what features?
I've seen newer cmv4.0 DV analysis(new L1) on streaming service MAX compared to iTunes old cmv2.9 but most of the time, it's the same.
Reset where can I find the presets for Davinici, sdr to hdr, hdr to sdr etc. ?
since I bought Resolve I don't want to share the preset anymore sorry but...thirdmoon wrote: Fri Sep 29, 2023 3:39 am Reset where can I find the presets for Davinici, sdr to hdr, hdr to sdr etc. ?
''hdr to sdr'' preset is the same as the ''DV generation'' settings, you just deliver the 100nits trim.
sdr to hdr:
Balthazar2k4
I have been blindly converting hundreds of my Dolby Vision UHD BDs to Profile 8 for compatibility, but now I am starting to wonder if there is a point. When I compare the Profile 7 and 8 results in Plex on either the AppleTV or Shield they look the same. Now I can't see them side by side, but am I just wasting my time or is there a benefit maybe I am just seeing? At this point the only advantage I can easily recognize is DV playback with Infuse on the AppleTV with the Profile 8 conversion (albeit it doesn't always work).
I am exactly in that position and didn’t convert my DV UHD BDs bcoz I wanted to convince myself objectively that I wasn’t loosing on PQ even if if can’t see a difference (even just MEL ones). This topic is quiet complex, I think one has to do pretty much the same amount of work and diligence that RESET9999 did to start reaching an understanding.Balthazar2k4 wrote: Sat Sep 30, 2023 12:28 am I have been blindly converting hundreds of my Dolby Vision UHD BDs to Profile 8 for compatibility, but now I am starting to wonder if there is a point. When I compare the Profile 7 and 8 results in Plex on either the AppleTV or Shield they look the same. Now I can't see them side by side, but am I just wasting my time or is there a benefit maybe I am just seeing? At this point the only advantage I can easily recognize is DV playback with Infuse on the AppleTV with the Profile 8 conversion (albeit it doesn't always work).
One approach is to use DV test pattern(s) and compare the performance of a reference DV player (Oppo 203) with ATV4K DV performance (by taking accurate photos of the screen), and that of Infuse or other DV software capable media streamer. I attempted to do this & you can find good reading starting w this https://forum.makemkv.com/forum/viewto ... 63#p135163 and the next few posts and replies from RESET9999.
One conclusion (whether significant or not), and dismissing any errors in the experiment, is that using that P8 DV test pattern, the Oppo shows elements of that test pattern that ATV (internal player) nor Infuse doesn’t. How does this reflect on PQ and what a human perceives during movie playback is a subject beyond me.
Maybe the convenience of having all digital media being available under the control of a streamer software (Infuse, …) trumps whatever PQ difference there may be. I’ll redo what I did w tvOS17 which brings P8 internal playback support.
It it possible to skip ProRes generation while converting HDR10+ to DV (using 3-1) or is it just better to use the old method if I want to do it quickly?
Profile 7 MEL is the same as Profile 8. I am baking FEL into encodes out of P7 FEL titles, and just creating profile 8 from P7 MEL and injecting it to HDR encode.aboulfad wrote: Sat Sep 30, 2023 1:05 pmI am exactly in that position and didn’t convert my DV UHD BDs bcoz I wanted to convince myself objectively that I wasn’t loosing on PQ even if if can’t see a difference (even just MEL ones). This topic is quiet complex, I think one has to do pretty much the same amount of work and diligence that RESET9999 did to start reaching an understanding.Balthazar2k4 wrote: Sat Sep 30, 2023 12:28 am I have been blindly converting hundreds of my Dolby Vision UHD BDs to Profile 8 for compatibility, but now I am starting to wonder if there is a point. When I compare the Profile 7 and 8 results in Plex on either the AppleTV or Shield they look the same. Now I can't see them side by side, but am I just wasting my time or is there a benefit maybe I am just seeing? At this point the only advantage I can easily recognize is DV playback with Infuse on the AppleTV with the Profile 8 conversion (albeit it doesn't always work).
^^^ Thanks, it is known that P7 MEL conversion to P8 is “lossless”. What I think was being pondered on, whether PQ for viewing a P8 movie is the same in a video processing chain using a reference video player vs the aforementioned software streamers (Infuse, Plex) on an ATV 4K.
Using the above test pattern, ATV DV processing of that P8 test pattern yielded different results than using the same pattern on an Oppo UDO-203 w same cables/TV. Reading S&M explanation of that test pattern kinda implies something funky happening with ATV DV processing for that P8 pattern.
Seeing difference between FEL and MEL/Profile 8/recodes and really enjoying it are two different things indeed.
To be able to assess, first off you must be able to see FEL in its full glory, which I think very few of us can do. It takes a native 12 bit screen in the first place and its ability to display full blown 12 bit luminance. To my knowledge there are none for consumers (yet?), unless things have changed. So be aware that you're probably watching down-to-10 bit FEL DV on your screen. Nevertheless, even then FEL can look better. Also, FEL advantage takes players which Dolby Vision Composer actually process FEL. Such as DV compliant UHDBD players and some mediaplayers.
I won't go into personal taste. I do think a lot of recoding is done to save up on harddrive space. For those who do experience FEL as the walhalla, won't do any of it, my guess.
aboulfad wrote: Sat Sep 30, 2023 3:53 pm ^^^ Thanks, it is known that P7 MEL conversion to P8 is “lossless”. What I think was being pondered on, whether PQ for viewing a P8 movie is the same in a video processing chain using a reference video player vs the aforementioned software streamers (Infuse, Plex) on an ATV 4K.
that P8 pattern file looks correct only on cmv2.9 devices.
It has issues on all the cmv4.0 devices.
ATV:
strange artifacts in the red and blue ramps
issues in the Y’CbCr clipping
Shield:
banding in the blue ramps (I think its the reason for the red push)
issues in the colorspace conversion (goes away in LLDV)
FireTV:
st2084 tracking different that all the other device.
looks darker
C2 internal player:
thank you for the summaryRESET_9999 wrote: Sat Sep 30, 2023 4:07 pm …
it doesn't matter it still uses the most recent CMV4.0 engine to playback DV regardless of the input version and the pattern is cmv2.9 anyway.aboulfad wrote: Sat Sep 30, 2023 4:18 pm thank you for the summaryfrom previous experiment: viewtopic.php?p=134248#p134248 , I think ATV can only process P8 w cmv2.9, does it mean it’s a cmv2.9 device ? so I am a bit confused by the above two statements.
Hmm, so if we had a cmv4.0 DV test pattern, would we expect better conformance to that test pattern on ATV?RESET_9999 wrote: Sat Sep 30, 2023 4:21 pm it doesn't matter it still uses the most recent CMV4.0 engine to playback DV regardless of the input version and the pattern is cmv2.9 anyway.
