What do I navigate to when ripping a blu-ray on my HDD?
galapogosian
Post by galapogosian » Thu Sep 28, 2023 2:01 am
When I use MakeMKV on DVD's, I go to the VIDEO_TS folder/file. What am I navigating to on a blu-ray? I went through the BDMV and CERTIFICATE folders and couldn't find anything it would open.
Re: What do I navigate to when ripping a blu-ray on my HDD?
Post by Woodstock » Thu Sep 28, 2023 2:44 pm
Your question is strange... When you OPEN a disk (BD or DVD), the normal way to do things is to select the tracks to rip, NOT to "navigate to" a folder.
galapogosian
Post by galapogosian » Thu Sep 28, 2023 7:23 pm
If you're doing it from your HDD, you are navigating to files in folders.
Post by MartyMcNuts » Thu Sep 28, 2023 10:54 pm
galapogosian wrote: Thu Sep 28, 2023 2:01 am When I use MakeMKV on DVD's, I go to the VIDEO_TS folder/file. What am I navigating to on a blu-ray? I went through the BDMV and CERTIFICATE folders and couldn't find anything it would open.
If you are talking about a BD disc already ripped to a folder, then I think the file you are looking for is called index.bdmv. (movieobject.bdmv should also work).
galapogosian
Post by galapogosian » Fri Sep 29, 2023 12:49 am
Thanks, Marty.
