LibreDrive for Pioneer drives
falconchips wrote:
Wed Sep 27, 2023 10:56 pm
Hi, I've got an external Asus drive that is actually a Pionner drive. It reads BD, but not UHD with MakeMKV 1.17.5 ('no disc inserted'), so... I'm doing something wrong or it is not a UHD drive. Any ideas?
OS device name: K:
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E101
Serial number: XXXXXXXX
Firmware date: 2018-08-22
Highest AACS version: 77
Drive platform: RS8511
Firmware version: E101/ID26
That's not a UHD drive
Not sure if it can be converted it might be able to convert It if its a rebranded ud03
Gmangt34
Post by Gmangt34 »
I grabbed a Pioneer BDR-XS07UHD from Adorama per the previous two posts. Crossing my fingers for a 3/3 success rate since it was the last one in stock! :D
falconchips
Post by falconchips »
Billycar11 wrote:
Wed Sep 27, 2023 11:01 pm
Sorry to bother you again. I'm new to this. Is there any way to do that?
falconchips wrote:
Wed Sep 27, 2023 11:35 pm
only way would be trial and error with me it very likely the drive could die
wildcat_betamax
Post by wildcat_betamax »
MotorUnsubtly wrote:
Wed Sep 20, 2023 10:59 pm
I bought a Pioneer BDR-XS07UHD from Amazon a few days ago. Got here today and it had the 1.02 firmware on it which worked out of the box with libredrive/makemkv.
https://www.amazon.com/dp/B00FGVPTHW?ps ... ct_details
The vendor that sold it to me on amazon was Adorama.
Very nice drive, and worked 100 percent out of the box with 0 issues. I don't know if all of them will have the 1.02 firmware, but mine did so figured I'd share this here.
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.02
Serial number: CBDL011396UC
Firmware date: 2022-10-24
Bus encryption flags: 13
Highest AACS version: 63
Drive platform: RS8E21
Firmware version: 1.02/ID05
Thank you, good sir! I followed your lead, and I got my BD-RW BDR-XS07U with Firmware 1.02 (via Amazon c/o Adorama) in the mail today. Seeing LibreDrive enabled out of the box brought a tear to me eye - LOL! Love it. Have a great day!
Gmangt34
Post by Gmangt34 »
Pioneer BDR-XS07UHD drive from Adorama arrived today with a MFD of February 2023, but with the correct firmware! (1.02) :D
Revision: 1.02
Serial number: XXXXXXXXXXXX
blind-s33r
Post by blind-s33r »
I ordered one of the last BDR-XS07UHD drives from Adorama, hopefully it comes on 1.02. Should be arriving in the next few days... Would be nice to have another drive other than my BU40N and my BP50NB40...
RedLeaderNegative
Post by RedLeaderNegative »
Hi all,
I have a new Pioneer drive (BDR-XD08 on platform RS9330) that I'm wondering if it would be possible to add to the SDF bin (according to mike admin's post, I think it's eligible?).
Product: BD-RW BDR-XD08
Revision: 1.02
Serial number: CFDLXXXXXXXX
Firmware date: 2022-12-27
Highest AACS version: 68
Drive platform: Pioneer RS9330
Firmware version: GENE
RedLeaderNegative wrote:
Mon Oct 02, 2023 4:45 am
Hi all,
Revision: 1.02
Nope. The firmware is December 2022 or newer. That can't be added yet. Still waiting on a solution.
RedLeaderNegative
MartyMcNuts wrote:
Mon Oct 02, 2023 5:16 am
Hi all,
Revision: 1.02
I see. Thanks for clarifying!
blind-s33r
Yup drive from Adorama was 1.02, while the packaging said feburary 2023, Dang happy about that!
OS device name: G:
Revision: 1.02
Serial number: ************
Just as a side note, This thing blows the bu40n and bp50nb40 out of the water on reading finicky discs, been trying to read a dvd on multiple drives and it always got stuck at the same point. The Pioneer just blew through it like it was nothing. I hope that the firmware issue gets sorted eventually cause I want to get a second one asap.
loopydoodle
Post by loopydoodle »
Is the Pioneer BDR-XD07TS supported? I see a BDR-XD07 in the list, is it the same model?
falconchips
For Billycar11:
I've just opened the case and yes, it's a Pioneer BDR-UD03ASW. Is there any chance to make it UHDfriendly? I've flashed a LG drive yesterday and now I can rip UHD but I would know for sure if I can convert this Pioneer too so I've a backup unit.
falconchips wrote:
Wed Oct 04, 2023 10:00 pm
For Billycar11:
you would not be able to flash this one you would have to buy one of my automated flashers email me for one I will make one for you.
loopydoodle wrote:
Wed Oct 04, 2023 8:23 pm
If the fw is from before 12/22 email me your makemkv drive info section and I will make a flasher for you see below for contact info.
loopydoodle
Billycar11 wrote:
Wed Oct 04, 2023 10:12 pm
Thank you. So without flashing your firmware, the drive will not be supported "out of the box"?
