Old version message
Bran84
Re: Old version message
Post by Bran84 » Sun Sep 24, 2023 12:15 pm
Getting the same thing... Iver uninstalled it like 4 times and still nothing. Following just to see if you get any info.
Voltaic
Post by Voltaic » Sun Sep 24, 2023 2:04 pm
I am also having this issue. I tried to uninstall and reinstall a couple of times with the same result.
Post by d00zah » Sun Sep 24, 2023 7:59 pm
Have you read thru the FAQ about BETA and PERMANENT keys.? The solution may be as simple as applying the latest beta key.
Voltaic
Post by Voltaic » Sun Sep 24, 2023 8:37 pm
@d00zah
That fixed the problem. I didn't consider it since it expires at the end of the month. Thank you!
Post by d00zah » Mon Sep 25, 2023 1:02 pm
Voltaic wrote: Sun Sep 24, 2023 8:37 pm @d00zah
No worries, but as Woodstock points out in another thread, be aware...
Woodstock wrote: Mon Sep 25, 2023 12:36 pm ...
Also note that the current key expires in a few days, so you'll have to do it again when the new key is issued.
sweharris
Post by sweharris » Mon Sep 25, 2023 9:21 pm
Philbert wrote: Sun Sep 24, 2023 7:47 pm I sent an admin a pm, and no reply. I think they are ignoring us beta users, hoping we'll cough up some cash. Maybe?
If you look at the main download page, 1.17.5 was just released for Windows and Mac today
MakeMKV v1.17.5 (25.9.2023)
I expect the Linux beta version will be out in due course.
Indeed, the files appear to be on the download site, but it's possible the forum post hasn't been updated.
https://www.makemkv.com/download/makemk ... 7.5.tar.gz
I haven't tested them, yet.
Cardinal
Post by Cardinal » Tue Sep 26, 2023 12:43 am
I got the 2 tar.gz files linked above, and used 7-zip to extract everything to standard folders. I don't know what the difference between them is really, but I used both. I can't find a .exe or .msi file to install with, and I'm stuck on how to proceed.
Also, I put in the beta code from viewtopic.php?f=5&t=1053, but that did not work for the 17.4 version. Also, the registration box come up only after the program has put up the notice of the 17.4 version being too old, allowed for the registration button to be clicked, then announced a fatal error and closed the main program.
Post by d00zah » Tue Sep 26, 2023 1:30 am
Cardinal wrote: Tue Sep 26, 2023 12:43 am I got the 2 tar.gz files linked above, and used 7-zip to extract everything to standard folders. I don't know what the difference between them is really, but I used both. I can't find a .exe or .msi file to install with, and I'm stuck on how to proceed.
IF you are looking for a .msi/.exe, I will assume you are running Windows. Those archives linked above are for linux installs.
Try https://www.makemkv.com/download/ for the Windows installer.
Cardinal
Post by Cardinal » Tue Sep 26, 2023 3:57 am
d00zah wrote: Tue Sep 26, 2023 1:30 am Try https://www.makemkv.com/download/ for the Windows installer.
Thanks, the 17.5 file just wasn't there when I kept trying to reinstall. I guess there's this gap between one version expiring and another being posted. I've never heard of a system like that.
Post by mike admin » Tue Sep 26, 2023 7:57 am
That was not intentional...
Voltaic
Post by Voltaic » Tue Sep 26, 2023 1:21 pm
@Philbert
Thanks for the PM, I'm new here and hadn't seen it and can't figure out how to reply :shock: :lol:
