BD-RE BH16NS40, LibreDrive safe?
JacketPotato
Post by JacketPotato »
Would I safely be able to flash this drive to LibreDrive firmware with Linux? MakeMKV says it is but it's not in the list of supported drives on this forum, an older revision is.
Drive Information:
OS device name: /dev/sr0
Product: BD-RE BH16NS40
Revision: 1.05
Serial number: XXXXXXXXXXX (redacted)
Firmware date: 2120-05-06 13:31
Highest AACS version: 75
Harware support: Yes
Firmware support: No
Firmware version: 1.05
Re: BD-RE BH16NS40, LibreDrive safe?
It is supported. It has encrypted firmware. So use the right command line option.
JacketPotato
Perfect, thanks. How safe is the process of flashing LibreDrive firmware?
JacketPotato wrote: Tue Sep 26, 2023 10:24 am Perfect, thanks. How safe is the process of flashing LibreDrive firmware?
100% safe if you follow the precautions in the guide
JacketPotato
Mordwho
Post by Mordwho »
I have the same drive, firmware, etc. looking to flash, did your process go smoothly?
JacketPotato
Never got round to doing it, might have a go this summer :)
