Keep getting "Fatal Error" message and closes Makemkv
Lord Deathless
Re: Keep getting "Fatal Error" message and closes Makemkv
Post by Lord Deathless » Mon Sep 25, 2023 4:37 am
I'm getting the same error I'm on Make MKV version 1.17.4. How do I attach my dump file on here? It won't let me it says "invalid file extension makemkv.DMP" when i try to attach it here.
Post by Woodstock » Mon Sep 25, 2023 12:33 pm
Right now, attached files don't work here. If the file is smaller than 50K, you could simply insert it between a set of code tags, so it could be viewed directly.
TK-24601
Post by TK-24601 » Tue Nov 14, 2023 4:12 am
I was able to use the software yesterday with no issues (11/12), but today I am getting the fatal error on v1.17.5. I tried installing the v1.17.4 and am still getting the same error. I am on Windows and I am not sure what else to try.
qwerty_6373
Post by qwerty_6373 » Tue Sep 17, 2024 9:26 pm
UNINSTALL THE APP AND REINSTALL THE MAKEMKV APP AND IT SHOULD WORK
