won't Open move sorry to post this here i dont know where to post this for help
What?
Post by What? » Fri Sep 22, 2023 9:07 pm
I have been using MKV for sometime and I have not had an issue like this. it will open the files but it does not one the movie file. it shows the movies file but it is only the menu video no the whole motion picture. is there anything i can do?
thanks for any help.
Re: won't Open move sorry to post this here i dont know where to post this for help
Post by Woodstock » Fri Sep 22, 2023 10:50 pm
Like your original post, you have given nothing to work with. We can't even say what disk you're trying to open, or why you've got a problem with it.
Radiocomms237
Post by Radiocomms237 » Fri Sep 22, 2023 11:23 pm
If you highlight the file name in the left pane, then look in the right pane under "Title information", what does it tell you for the "Duration"?
It sounds to me like you may be selecting the incorrect file to rip?
What?
Post by What? » Sat Nov 11, 2023 12:50 am
I was going to take screen shot but it worked this time thanks for help
