making ISO of uhd BD
666JTK666
Post by 666JTK666 »
is there a way to make an ISO of a UHD BD ?
ty fella's
kaelef
Re: making ISO of uhd BD
Post by kaelef »
Make a backup of the disc using MakeMKV, then create an ISO of that folder using ImgBurn.
666JTK666
Post by 666JTK666 »
Ok how do i configure makemky to do a backup of a disk ?
Insert the disk, when MakeMKV displays the large disk icon, click on the "Backup" button instead.You'll be asked whether you want it decrypted or not. Check your appropriate option.
Make sure you have enough space on your drive for the files.
Radiocomms237
Post by Radiocomms237 »
You don't really have to make sure there's enough space on the destination drive, MakeMKV does that check for you and if not it will present a popup asking for your input before commencing.
I see that damn popup quite often as I'm constantly running out of space on my PC and having to transfer completed files up to my NAS.
