LibreDrive compatible drive required to open disc
baryoncode5
I purchased archgon Stream UHD External 4K Ultra HD BD Player, External Blu-ray BDXL Burner for PC Laptop USB 3.0 / -C, M-Disc, Protective Box, External UHD BluRay Drive, External Blue-Ray Drive, Aluminum Black and get an error saying that I need a libredrive compatible drive, Can I fix the drive I have to make it work or do I need another drive and which one?
Re: LibreDrive compatible drive required to open disc
What does MakeMKV say about your drive? Post contents of 'Info' box (right side of the window).
baryoncode5
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.02
Serial number: MOAM5VG4754
Bus encryption flags: 1F
Highest AACS version: 76
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Disc Information
Label: THE_BATMAN
Timestamp: 2022-03-28 16:10:33
Protection: AACS2.0/C v76
Data capacity: 91.35 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Revision: 1.02
Disc Information
Label: THE_BATMAN
Number of layers: 3
baryoncode5
I've looked at that before but I'm not sure what to do.
Download the MK firmware and SDFTool flasher. Flash the 204 MK firmware from the ASUS folder to your drive. If you feel uncomfortable contact Billy and he will send you an automated flasher for $25.
THIS IS COMPLETELY WRONG!!!Coopervid wrote: Fri Sep 22, 2023 7:45 pm Download the MK firmware and SDFTool flasher. Flash the 204 MK firmware from the ASUS folder to your drive. If you feel uncomfortable contact Billy and he will send you an automated flasher for $25.
Do not do this. Your Archgon is a LG BU40N. Use SDFtool Flasher to flash your drive with BU40N 1.03-MK firmware and you are good to go.
Sorry Marty! I responded to the wrong post. My bad!
