dapope
#8926 Post by dapope » Fri Sep 22, 2023 12:04 am
Hi! Is there any explanation of the 7-5-3 workflow (playing FEL files with MPC)? I assume there's no way for windows to actually launch the display into dolby vision, so is this somehow showing the dynamic metadata using regular HDR output?
I also haven't been able to get the workflow to launch yet, I'm getting error messages (see image link).
It's possible I don't have MPC installed correctly, I downloaded the portable version and put it in the tools folder. But not sure if it matters whether I use the 64 or 32 bit version, or what the name for the MPC folder should be.
Thank you!
https://imgur.com/a/yRoA1tN
#8927 Post by Coopervid » Fri Sep 22, 2023 12:07 am
dapope wrote: Fri Sep 22, 2023 12:04 am Hi! Is there any explanation of the 7-5-3 workflow (playing FEL files with MPC)? I assume there's no way for windows to actually launch the display into dolby vision, so is this somehow showing the dynamic metadata using regular HDR output?
I also haven't been able to get the workflow to launch yet, I'm getting error messages (see attached file).
Thank you!
My point just above your post. Tell me why you are going through all these hassles.
#8928 Post by RESET_9999 » Fri Sep 22, 2023 12:57 am
Thank you!
Only FEL, the dynamic metadata are not used and no it won't trigger DV but you can watch in HDR10 or SDR.
It looks like your input(p7 ST I guess?) failed to be demuxed with dovi_tool.
here's the tool pack: https://mega.nz/file/VedxEIBB#bfjgWeSpr ... NCIC372rQQ
quietvoid
#8929 Post by quietvoid » Fri Sep 22, 2023 1:10 am
danbez wrote: Thu Sep 21, 2023 10:19 pm @quietvoid, can you explain your method ? Or send a link where I can learn about it? Thanks!
I don't provide support, it's in VapourSynth: https://github.com/OpusGang/awsmfunc/bl ... e.py#L1905
Iam2smart
#8930 Post by Iam2smart » Fri Sep 22, 2023 5:49 am
RESET_9999 wrote: Thu Sep 21, 2023 9:52 pm ok your file is cmv4.0 but only for the first two frames so you should remove it completely.
I fixed your file but it still has CMV4.0 and because the original was just for two frames, my fixed rpu generated static L3 metadata: https://drive.google.com/file/d/1Nvixsu ... sp=sharing
L2 trim pass seems fine in the fixed version:
https://slow.pics/c/UFLAJbOr
Great Thanks that fixed it my only other issue is my Elf copy. I've attached the XML file. I've done other movies and they work great
https://drive.google.com/file/d/1N98jY6 ... sp=sharing
dapope
#8931 Post by dapope » Fri Sep 22, 2023 7:52 am
RESET_9999 wrote: Fri Sep 22, 2023 12:57 am
Thank you!
OK interesting, thank you.
#8932 Post by RESET_9999 » Fri Sep 22, 2023 1:08 pm
Iam2smart wrote: Fri Sep 22, 2023 5:49 am Great Thanks that fixed it my only other issue is my Elf copy. I've attached the XML file. I've done other movies and they work great
there's no L2 error on my copy of Elf (p5 iTunes)...
why do you share the XML instead of the rpu? maybe you're using an old version of dovi_meta(tool that converts rpu to XML)?
Iam2smart
#8933 Post by Iam2smart » Fri Sep 22, 2023 2:11 pm
RESET_9999 wrote: Fri Sep 22, 2023 1:08 pm
That was the issue I updated dovi_meta tool from version 0.2.0 to 0.2.1 now I dont have any errors and everything works. Thanks for the help
danbez
#8934 Post by danbez » Fri Sep 22, 2023 2:43 pm
quietvoid wrote: Fri Sep 22, 2023 1:10 am
Thanks. I will try it out.
axeyou
#8935 Post by axeyou » Sun Sep 24, 2023 12:48 am
When taking FEL screenshots with DoViBaker in AvsPmod, is there a good way to tone map to SDR? I've tried the default generated script as well as applying the 100-nit L2 trim to DoViBaker through "trimPq=2081, targetMaxNits=100, targetMinNits=1". Both look too washed out compared to CAH's 100-nit conversion. https://slow.pics/c/l7iEtcS3
#8936 Post by RESET_9999 » Sun Sep 24, 2023 1:53 pm
axeyou wrote: Sun Sep 24, 2023 12:48 am When taking FEL screenshots with DoViBaker in AvsPmod, is there a good way to tone map to SDR? I've tried the default generated script as well as applying the 100-nit L2 trim to DoViBaker through "trimPq=2081, targetMaxNits=100, targetMinNits=1". Both look too washed out compared to CAH's 100-nit conversion. https://slow.pics/c/l7iEtcS3
I guess you would have to add libplacebo in the script.
You can use 7-5-3 (madVR +MPC) which has the best HDR to SDR tone mapping anyway.
LoadPlugin("D:\DoVi_Scripts\tools\DoViBaker_x64.dll")
LoadPlugin("D:\DoVi_Scripts\tools\dgdecnv_242\DGDecodeNV.dll")
LoadPlugin("D:\DoVi_Scripts\tools\avs_libplacebo.dll")
bl = DGSource("D:\\P7_BL.dgi")
el = DGSource("D:\\P7_EL.dgi")
DoViBaker(bl, el, rpu= "D:\\P7RPU_FEL.bin")
libplacebo_Tonemap(src_csp=1, dst_csp=0, dynamic_peak_detection=true, tone_mapping_function=0, tone_mapping_mode=1)
Trees
#8937 Post by Trees » Sun Sep 24, 2023 3:24 pm
I'm trying to inject HDR10+ metadata into an HR10 remux. However, the HDR10+ metadata is delayed by 24 frames.
How do I sync them? I'm familiar with syncing with dovi_tool, but I'm afraid it won't work with HDR10+.
axeyou
#8938 Post by axeyou » Sun Sep 24, 2023 9:37 pm
RESET_9999 wrote: Sun Sep 24, 2023 1:53 pm I guess you would have to add libplacebo in the script.
Thanks, RESET! libplacebo looks much better!
Do you also happen to know how to apply it to BL only? It looks like it doesn't accept a DGSource("BL.dgi") as input:
LoadPlugin("D:\DoVi_Scripts\tools\dgdecnv\DGDecodeNV.dll")
DGSource("D:\Movies\\00009\00009_BL.dgi")
# libplacebo_Tonemap: failed uploading data to the GPU! Trying alternative RGB32 conversion. Attempt failed !
libplacebo_Tonemap(src_csp=1, dst_csp=0, dynamic_peak_detection=true, scene_threshold_high=-1)
#8939 Post by RESET_9999 » Sun Sep 24, 2023 10:37 pm
it works fine on my end
btw I added support in the latest dovi_scripts workflow 7-1 for SDR tone mapping line 119 set tonemap=0
axeyou
#8940 Post by axeyou » Sun Sep 24, 2023 11:47 pm
Thanks again, RESET! I guessed I just hit some bug. Restarted AvsPmod and it worked fine : )
Appreciate your help!
