Lazarus
Re: SDFtool Flasher
Post by Lazarus » Thu Sep 21, 2023 11:57 pm
Hello
I have an LG WH16NS40 drive (rev 1.05), version 1.17.4 of MakeMKV installed. I am trying to run SFDtool Flasher and I get a Microsoft .NET error of Unhandled exception. If I continue past the error the app loads but the select drive box is blank. MakeMKV sees the drive correctly as a MT1959 platform. I am running Windows 11. Is the error because of Win11?
Re: SDFtool Flasher
Post by MartyMcNuts » Fri Sep 22, 2023 5:54 am
Hello
Are you running SDFTool Flasher v1.3.5? What is the exception?
Snarglefarg
Re: SDFtool Flasher
Post by Snarglefarg » Sat Sep 23, 2023 7:44 am
I'm using Windows and here's what I did to fix it:
  • Click Start
  • Type "Turn Windows features on or off
  • Select .NET Framework 3.5 (includes .NET 2.0 and 3.0)
  • Select .NET Frame 4.8 Advanced Services
  • Click OK to install. It will take a while
  • When done, run the program and it will work.
I suspect that you only need .NET Framework 4.8 but I didn't test that, just check both and you should be good. Once you're done, you can go back and uncheck them to remove them.
Good luck!
jeeenyus
Re: SDFtool Flasher
Post by jeeenyus » Sat Sep 23, 2023 2:57 pm
https://imgur.com/a/F3wMsMO
Not the same problem as Lazarus has above. I don't think, same drive...except I'm still on windows 10.
This is what I get when flashing:
Command line produced error code: 0x82052603
see screenshot for relevant info. (LG wh16ns40 - 1.17.4mkv (.net 3.5 and 4.8 on per SnargleFarg post) and flasher 1.3.5
Re: SDFtool Flasher
Post by MartyMcNuts » Sat Sep 23, 2023 9:18 pm
Make sure the drive tray is empty and closed and that MakeMKV is installed in the default location which is (C:/Program Files (x86)/MakeMKV)
jeeenyus
Re: SDFtool Flasher
Post by jeeenyus » Sat Sep 23, 2023 9:41 pm
"C:\Program Files (x86)\MakeMKV\makemkv.exe"
closed and no disk.
0x82052603
poop.
dr_sherman
Re: SDFtool Flasher
Post by dr_sherman » Sun Sep 24, 2023 7:29 pm
I am attempting to read (and then flash) a WH14NS40 (v1.05). MakeMKV installed, Beta key applied, drive detectable within SDFtool.
When I attempt to read the firmware a dump directory is created but is blank. When I attempt to flash 'HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936' the application provides no indication that it has registered the command. This means I do not see an error, nor does the drive flash. Please forgive the silly question, I have tried to search the thread but nothing is jumping out at me!
Thanks for your help in advance
Re: SDFtool Flasher
Post by MartyMcNuts » Sun Sep 24, 2023 9:16 pm
closed and no disk.
0x82052603
poop.
How is your drive connected to the PC?
What firmware are you trying to flash? If your drive came with encrypted firmware you must flash WH16NS60 1.02-MK first. You can then use this firmware (recommended with MakeMKV) or flash another firmware.
magingen
Re: SDFtool Flasher
Post by magingen » Mon Sep 25, 2023 9:44 am
Bug: the tool launched stuck behind my taskbar, and the usual commands to move it don't work, meaning I have to move my taskbar manually, move the tool, then move the taskbar back.
JBKFlynn
Re: SDFtool Flasher
Post by JBKFlynn » Sat Sep 30, 2023 8:02 pm
Just HAD to comment: this tool is a lifesaver- I'm incredibly grateful for the hard work you put into it; I honestly thought I was going to have to ditch the drive I just snagged, but you saved the day! :)
Many, MANY thanks!
socom23
Re: SDFtool Flasher
Post by socom23 » Fri Oct 06, 2023 2:52 pm
Thanks for this tool!
I've now been able to flash my LG-BH16NS55 after getting the following error code - 0x82052603 with DE_LG_BH16NS55_1.02.bin
Managed to resolve this by selecting DE_LG_WH16NS60_1.00.bin
Ripped Tinker tailor to MKV and all working fine now.
WinterSoldierUK
Re: SDFtool Flasher
Post by WinterSoldierUK » Tue Oct 10, 2023 11:25 am
Hi - Just bought an LG BP55 and want to make sure I don't mess this up - can someone confirm what is the correct firmware file to use for this drive please?
Re: SDFtool Flasher
Post by MartyMcNuts » Tue Oct 10, 2023 10:30 pm
Not sure what this drive is. What is the model?
WinterSoldierUK
Re: SDFtool Flasher
Post by WinterSoldierUK » Wed Oct 11, 2023 7:50 am
Here's an Amazon link, has pictures of the serials etc.
Hitachi-LG BP55 External Blu-Ray Drive, USB 2.0 Slim Portable Player/Rewriter for Laptop, Desktop PC, Windows 11 Compatible, with TV Connectivity, 3D Playback, 8x Read/Write Speed - Black https://amzn.eu/d/0aUDePF
It's flashable to my knowledge just not sure what the correct firmware is.
Re: SDFtool Flasher
Post by MartyMcNuts » Wed Oct 11, 2023 10:22 pm
That's a BP55EB40. If you said that, I would have known what it was. The recommended firmware is BU40N 1.00, which will work with all popular ripping software. The flashing process may differ, depending on how new the drive is. It should have a SVC code written underneath and also on the side of the box where the model / manufacture date is. Let me know the manufacture date and the SVC code and I can advise further,
